Created on: 25 Nov 2015 10:27
Koempy
I'll start right away.
Before March 2014:
After May 2015:
-XIII-
4 Dec 2019 23:00
The concrete slab has now been poured. This finally allows me to get a real sense of the house’s dimensions. Tomorrow, the first basement walls will go up, and it looks like we’re lucky with the weather. Daytime temperatures should stay around 5°C (41°F) until Christmas, which means completing the entire basement this year still seems achievable.
Gegossene Betonfundamentplatte in Baugrube, Bewehrung am Rand, Erde drumherum.
Baustelle mit frisch gegossener Bodenplatte, Stahlbewehrung, Holzformwerk, Haus im Hintergrund.
Dr Hix4 Dec 2019 23:26
Tina mit K schrieb:
The materials for processing are on hand, and we definitely won’t get bored.
Be careful with the primer; it sticks like crazy and, combined with construction debris flakes and dust, creates square meters of a grainy 40-grit “floor covering.”
Always use a fleece underneath, and if you apply it by spraying, it’s best to cover the windows completely with tape.
Tina mit K4 Dec 2019 23:38
Dr Hix schrieb:
Be careful with the primer; it’s extremely sticky and, combined with construction debris particles and dust, creates a layer of grit across several square meters of the floor covering (grain size 40).
Always use fleece underneath, and if you spray it, it’s best to fully tape off the windows as well.
Ah, okay, good to know. Of course, we want to lay the floors only after all the walls are finished, but having to skim over more than 120 sqm (1300 sq ft) again to scrape off such residues is something we’d like to avoid.
Climbee5 Dec 2019 08:50
Today’s view from our bathroom window:
Winter scene with frost-covered tree branches by the river under a blue sky.
And no one can look in the other way around.
Yosan
5 Dec 2019 09:34
Our small bathroom is starting to take shape.
Bathroom corner with light wall tiles, vertical mosaic strip, two white light switches.
Shower wall with light tiles, mosaic strip and red/blue water connection, construction work in the bathroom
Tina mit K5 Dec 2019 10:15
I just received fresh photos because the last part of the scaffolding was removed this morning. I believe we have chosen the right house.
White single-family house construction site with dark tiled roof, porch, windows, and black van.
Modern white single-family house at construction site with large windows, other houses next to it.
Modern white house with large windows and gable, construction site with soil in the foreground.
Shell construction room with large window fronts, view outside, construction materials and buckets.
