I am currently facing the challenge of assembling an IKEA Platsa wardrobe on a significantly uneven floor. Specifically, it is an older wooden floor with visible irregularities of about 1.5 to 2 cm per meter (0.6 to 0.8 inches per 3.3 feet), occurring both lengthwise and crosswise. I want to build the wardrobe as stable and durable as possible, without it wobbling or experiencing stress caused by uneven support surfaces.
My question is: What technical and practical approaches are recommended specifically for installing PLATSA systems on uneven floors? I am particularly interested in tips for leveling, anchoring, and preventing material strain due to slope. I would also appreciate suggestions for additional accessories or alternative installation methods suitable for this situation.
Basically, I recommend leveling uneven floors before installation to ensure an even distribution of load. This is especially important for IKEA PLATSA because uneven pressure can damage the connection points over time. Two proven methods: - Use adjustable furniture feet (either IKEA’s or standard market versions) under the cabinet and adjust them individually. - Place leveling plates or wooden wedges, secured with brackets, to precisely compensate for the unevenness. Floor leveling compounds are also an option if the unevenness is several centimeters (inches) and you want a long-term solution. Anchoring to the wall further reduces the risk of tipping. PLATSA is normally attached to the wall, which is even more important on uneven floors.
I would describe my approach in several steps: 1. First, measure the floor at the installation site very carefully—using a spirit level and a straightedge is best, as this helps to accurately identify any unevenness. 2. Purchase furniture legs with threaded stems that are individually height-adjustable—while IKEA offers their own, depending on the situation, sturdier external legs may also be advisable. 3. If a larger adjustment is needed, you can prepare wooden structures yourself: small wooden blocks or custom-cut wedges, precisely sawed and connected with angle brackets, create a stable base. 4. When installing PLATSA, always check whether sliding shelves or doors still operate smoothly. Uneven settling otherwise causes jamming. 5. Finally, be sure to fasten the unit to the wall, preferably with heavy-duty anchors, to prevent the cabinet from tipping over. My question to you: Is the floor simply sloped, or are there specific areas that are truly unstable, such as loose floorboards or substrate?
Le_kin schrieb:
My question to you: Is the floor simply sloped, or are certain areas actually wobbly, like loose floorboards or subfloor? Thank you for the detailed analysis. The floor is slightly springy in some spots, as it consists of wooden boards that aren’t tightly wedged everywhere, but overall there are no loose boards. The unevenness mainly results from somewhat uneven installation in the older building—the greatest height difference is about 2 centimeters over 1 meter (0.8 inches over 3.3 feet). I think adjustable feet could help, but I’m still uncertain whether I can attach the feet firmly to the cabinet frame or how that would work with the PLATSA system.
RonJarrett11 Jan 2021 10:11Regarding adjustable feet: IKEA PLATSA itself is sold without height-adjustable feet, but the modules are designed to allow some flexibility for adjustment. Conveniently, additional height-adjustable furniture feet can be purchased separately and attached to the underside of the base frames with screws. It is important that these feet have a central screw connection that can be fastened into the load-bearing beams of the PLATSA frame. This allows the cabinet to be aligned with millimeter precision. Additionally, I recommend equipping the feet with non-slip rubber pads to prevent sliding on wooden floors. Finally, secure attachment to the wall should not be neglected, as the cabinet can easily tip over on uneven floors.
RonJarrett schrieb:
This is how the cabinet can be aligned with millimeter precision. I consider it risky to rely solely on adjustable feet. Especially with PLATSA, whose modules are not particularly heavy, there is a risk that they may slowly shift under load or that the screws could loosen. Personally, I would have concerns about whether the effort required for proper stabilization might be better invested in a more comprehensive floor renovation. An alternative is to avoid installing the cabinet directly on the floor and instead secure a support frame to the wall, mounting the PLATSA essentially suspended on it. Although this is more complex, it reduces stress on the furniture and protects the structure.
