ᐅ How can I safely install IKEA Platsa units on drywall (gypsum board) walls?
Created on: 1 Aug 2017 08:21
pauline1Hello everyone, I’m planning to install an IKEA Platsa cabinet on a drywall and want to do it as safely and securely as possible. Since the wall is made of drywall, I’m unsure which mounting method is best to prevent tipping or accidents. I’ve heard that special anchors or perhaps additional reinforcement might be needed because drywall alone isn’t very load-bearing. Does anyone have experience with safely mounting IKEA Platsa on drywall? What approach would you recommend, which anchors are suitable, and are there any specific tips on how to distribute the load optimally? Thanks in advance for your advice!
Hello Pauline, your question is very well formulated and equally important to ensure your cabinet is securely mounted. When dealing with drywall (gypsum board) walls, caution is necessary because the material does not support weight as well as a solid wall. For an IKEA Platsa cabinet—which can be quite heavy, especially when fully loaded—I strongly recommend using hollow wall anchors or special drywall anchors that are rated for heavy loads.
Additionally, if possible, you should plan the installation precisely where there is a wooden stud or a metal framing behind the drywall. This way, you can screw directly into the stud, which is always the better option. If you are unsure of the exact locations, using a stud finder (circuit detector) is very helpful.
If that is not possible, then anchors that expand or spread inside the drywall to grip a larger area behind the board should be used to distribute the weight. Avoid cheap plastic anchors or simple expansion anchors that are not designed for high loads.
To summarize:
- Screw into the stud whenever possible
- Use appropriate hollow wall anchors for drywall
- Pay attention to the maximum load capacity of the anchors
If you like, I can provide specific product recommendations.
To summarize:
I would like to respond to your question with a more structured approach and provide you with a step-by-step guide on how to securely mount an IKEA Platsa system on drywall.
1. Check the wall structure: Use a stud finder to locate the metal or wooden studs behind the drywall panel.
2. Plan the fixing points: Ideally, attach the cabinet directly to these load-bearing studs.
3. If no studs are available, you will need special hollow wall anchors that can withstand high tension and shear forces, such as metal anchors or toggle bolts.
4. Pre-drill: Drill holes for the anchors carefully and straight to avoid damaging the drywall panel.
5. Insert the anchors: Place the anchors into the pre-drilled holes and make sure they open and grip correctly.
6. Position the cabinet and screw it in place: Tighten the screws firmly but do not overtighten to avoid damaging the anchors or the drywall.
Common mistakes are:
- Using anchors designed for light loads
- Drilling without checking the wall structure beforehand
- Screwing the screws either too loosely or too tightly
To increase load capacity, you can also use multiple anchors distributed to spread the weight.
If you don’t have a stud finder, the classic knock test often helps: Can you hear the difference between hollow and solid? Even though it’s a bit old-fashioned, this method usually works quite well on drywall panels to locate the studs. Just make small marks where you find them. My advice: build several small support assemblies to distribute the load smartly. An IKEA Platsa might look sturdy, but drywall is basically a paper armor – without the right anchors, you’ll quickly run into trouble 😉!
nikian schrieb:
Also, you should try to plan the installation precisely where there is a wooden stud or a metal framing profile behind the drywall.Thanks, that sounds very reasonable! Today I tested with a stud finder and actually found several metal profiles, so I plan to attach the Platsa there. Since I’m not entirely sure whether it’s allowed to screw directly into the metal profile or if I need a washer or something similar – does anyone have recommendations on how to fasten screws with high load capacity to metal profiles?
naujon schrieb:
Avoid cheap plastic anchors or simple expansion anchors that are not designed for high loads.Which anchors are specifically suitable for metal studs? I haven’t found anything fitting, only those “metal profile with screws” sets. Please help, I don’t want to make any mistakes.
