ᐅ How reliable are the connections in Ikea PLATSA?
Created on: 30 Jun 2018 08:37
kardi
kardi
30 Jun 2018 08:37
Hello everyone, I am currently planning to buy an Ikea Platsa system and am looking into the question: how secure are the connections in Ikea PLATSA really?
Specifically, I’m interested in whether the screws, dowels, and fasteners hold up to everyday use, especially when the modules are used for heavy loads or over long periods. Are there any noticeable weak points or specific connection areas in PLATSA that tend to cause problems?
Since I plan to assemble the furniture on slightly uneven floors, it would be helpful to know if this affects stability. Does anyone have experience with the stability and durability of the connections when the modules are screwed and assembled?
I’m looking forward to your assessments and tips, especially regarding which types of connections in PLATSA are generally considered reliable or not.
botibo
30 Jun 2018 09:18
Hey kardi, a very precise question! 😊 I’ve had PLATSA for a year now, and not a single part has loosened or become wobbly – even when the compartments are fully loaded.
The connections are cleverly designed with dowels and screws that you can tighten firmly. Of course, if you over-rotate or handle them too roughly in one spot, something might give, but for everyday use, they are definitely sturdy enough.
Uneven floors? Just counteract with suitable felt pads or small shims to stabilize the entire unit. Overall: my advice is that PLATSA is quite durable!
Rosaren
30 Jun 2018 09:47
For additional information: Ikea PLATSA uses standardized dowel and screw connections that are quite load-bearing when assembled correctly. It is important that all connections are cleanly assembled and follow the instructions carefully.
Regarding stability, it can make sense to connect the modules to each other or secure them to the wall, especially with taller or freestanding units.
If the floor is slightly uneven, it is also advisable to make appropriate adjustments, as otherwise the load on individual parts may be unevenly distributed, which can lead to weaknesses over time.
koanbar
30 Jun 2018 10:05
The connections are generally stable if everything is assembled correctly. Important:
- Tighten all screws securely
- Use brackets and connector pieces
- Don’t forget wall mounting for larger modules
Otherwise, it will quickly become unstable.
BOSUDA
30 Jun 2018 10:22
No issues with my PLATSA shelves. Important: fully assemble the system, don’t just slot it together, and check all screws several times. Then it will hold like a rock.
INGRID34
30 Jun 2018 11:13
I can only agree with Rosaren. Additionally, I recommend not inserting the plastic anchors too deep. When properly installed, they provide very good stability for the connections.
