I am considering getting the Ikea Platsa system, but my usage situation is a bit special: I will likely rearrange the furniture regularly because I am redesigning my apartment and want to remain flexible.
My specific question is: How stable are Ikea PLATSA furniture pieces when they are moved and disassembled frequently? Does the stability or fit of the connections deteriorate with repeated assembly and disassembly?
I am particularly interested in the durability of the screw connections, the hinges, and the material itself. Are there users who have assembled and rearranged the furniture multiple times and can share whether the pieces become wobbly or show any damage over time?
I look forward to your experiences and insights. Thanks in advance!
What I’m more curious about is why people always have to rearrange their furniture. Isn’t that somewhat the Achilles’ heel of PLATSA? Ikea offers affordable options, but I have some doubts about the comfort regarding flexibility and long-term stability.
In general: If you frequently assemble and disassemble furniture, every piece will suffer.
Regarding the stability of Ikea PLATSA when frequently rearranged, it can be said that the design is basically intended for modular adjustments. However, the screw connections and cam lock fittings are not designed for continuous, frequent disassembly.
There are reports that after 3-4 complete assembly and disassembly cycles, the drilled holes tend to wear out, which can lead to some looseness. Especially the thin hardboard back panel does not contribute to rigidity if it is removed often.
My advice: If you rearrange regularly, make sure to carefully retighten the screws and consider replacing parts or adding reinforcements if necessary.
I can organize this a bit:
1. Materials: PLATSA mostly uses particle boards with foil coating and plastic fittings.
2. Joints: Cam lock connectors and screws designed for occasional assembly.
3. Frequent relocation: The hardboard back panel, which provides stability, is particularly affected.
4. Advice:
- Always use the appropriate tools.
- Regularly tighten the screws.
- When reassembling, check the holes and repair them with wooden dowels if necessary.
Conclusion: PLATSA is not professional-grade furniture for constant assembly and disassembly, but with care and maintenance, it can withstand several moves.
4. Advice:
fredle schrieb:
PLATSA is not a professional-grade piece of furniture designed for frequent assembly and disassembly, but with care and maintenance, it can withstand several moves.Thank you, that sums it up perfectly.
To be a bit more specific: I’m also interested in whether certain connectors are particularly vulnerable when reused, or if there are alternative techniques that can help maintain stability.
Are there perhaps screws or reinforcements from third-party suppliers that work especially well with PLATSA? Or tips on how to carefully take the furniture apart and put it back together without damaging the drilling holes?
