ᐅ What to do about wobbly IKEA PLATSA shelves?
Created on: 5 Jun 2024 08:17
AMINKLA
AMINKLA
5 Jun 2024 08:17
Hello everyone, I have installed several IKEA Platsa units on the wall and have noticed a slight wobbling, especially when the shelves are loaded. My question is how to effectively and permanently eliminate this wobbling? I have checked the basic setup; the units are properly assembled and attached using the IKEA mounting brackets, which I consider stable. However, I still feel a bit of movement, particularly at the corner joints. Does anyone have experience with tips or tricks to secure wobbly Platsa units against swaying or rocking? Thank you in advance for any advice! Which additional measures provide the most stability?
Franck
5 Jun 2024 08:45
Hi, the most effective way is to additionally secure the shelves to the wall using angle brackets. Also, make sure to insert screws into wall plugs. This will make them less movable.
Davidleo
5 Jun 2024 09:03
I had the same problem! For me, tightening all the screws properly again and using strong wall anchors helped. After that, everything was quiet! Just don’t give up, you can do it!
Lorukeo
5 Jun 2024 09:29
It is important that the mounting surface is completely level. Uneven floors or walls can cause wobbling, even if the structure itself is stable. Using additional back panels on the shelving units significantly increases stability. IKEA PLATSA modules are designed for wall mounting – the attachment must be secured to load-bearing points using appropriate anchors.
theo63
5 Jun 2024 10:01
I believe the load capacity of the shelves should also be critically evaluated. Especially with PLATSA, the connections are not designed for very heavy loads. Wobbling can also be a sign that the units are being used beyond their load limits. Therefore, reduce the load or consider additional reinforcements.
AMINKLA
5 Jun 2024 10:18
theo63 schrieb:
Wobbling can also be a sign that the modules are being used beyond their load capacity.
That’s a good point, thank you. I estimated the load roughly based on IKEA’s specifications, but I could take more precise measurements. Are there any recommendations on how to better monitor the actual load capacity during everyday use? Is it possible to assess this without complex measurement procedures?
