ᐅ How reliable is the wall mounting for Ikea PLATSA?
Created on: 30 Oct 2022 14:23
Lira69
Lira69
30 Oct 2022 14:23
I would like to start a discussion on the topic: “How secure is the wall mounting for Ikea Platsa?”
Specifically, I am interested in the typical load capacity of the mounting hardware when installing the units on a standard drywall. My goal is to understand whether the mounting materials provided by Ikea (screws, anchors, brackets) are generally sufficient to securely fix the cabinets over the long term, or if additional measures (different types of anchors, extra reinforcements) would be advisable.
It would also be helpful to hear about experiences regarding how critical it is to strictly follow the included assembly instructions, and which common mistakes should be avoided. I appreciate any tips on how to optimize the stability, especially considering different wall materials!
U
usbla
30 Oct 2022 14:47
Basically, the wall mounting for Ikea PLATSA is adequately sized for a standard drywall installation when following the assembly instructions for the intended use.
- Ikea usually provides plugs and screws suitable for solid walls, but for drywall, it is better to use specialized hollow wall anchors.
- The load capacity per bracket is generally around 20-25 kg (44-55 lbs), depending on the type of anchor used.
- It is essential to follow the recommended installation height and the number of fixing points as specified in the instructions.
Additionally, I recommend checking the wall condition before installation and opting for professional-grade anchors if there is any uncertainty.
KINMIN4
30 Oct 2022 15:10
If you attach PLATSA to drywall, be sure to use hollow wall anchors. Ikea anchors alone are not really strong enough.
PAREL
30 Oct 2022 16:02
For a more detailed explanation:
When attaching PLATSA modules to the wall, the load-bearing capacity of the wall is the limiting factor. Drywall is generally less stable than solid walls. Therefore, the first rule is to choose appropriate anchors for the wall; otherwise, the entire structure will not hold.
Steps for optimal fastening:
- First, check if the wall is made of solid material (concrete, brick) or drywall.
- For drywall, special cavity anchors (e.g., toggle bolts or metal expansion anchors) are suitable.
- Make sure to use all recommended fastening points—more is better than fewer.
- For larger modules, it can help to fix a wooden batten behind the drywall (if accessible) to anchor screws into a load-bearing material.
- Choose screws and anchors according to the wall type; do not rely solely on those supplied by Ikea.
Common mistakes include ignoring the package instructions or using unsuitable anchors, which leads to instability.
In short: IKEA’s assembly instructions are a minimum requirement and should usually be improved by using suitable anchors for the specific wall.
barle
30 Oct 2022 17:18
My PLATSA furniture holds well on the wall, but I used hollow wall anchors for drywall, as recommended in the instructions on my anchor packaging. This keeps everything stable.
lorena
31 Oct 2022 09:32
I would like to go into more detail on this topic, especially since some points are often overlooked:
1. Precisely determine the wall type: There are significant differences between simple drywall, double-layer cladding, lightweight partition walls, and load-bearing walls. The material determines the type of anchors to use.
2. Load profile of the PLATSA modules: Depending on the size and weight of the storage unit, the load on individual fastening points varies. For example, a smaller wardrobe for clothing is easier to mount than a large unit filled with heavy contents.
3. Ikea’s assembly instructions follow general standards and do not account for all wall types individually. For instance, the included screws are designed for solid walls; drywall always requires hollow wall anchors, otherwise nothing will hold.
4. Screw length and anchors must be matched to the wall thickness and material. Many underestimate the importance of this. A screw that is too short can almost completely compromise stability.
5. Check the installation before loading: After attaching the modules, carefully test them for any slight wobbling or creaking and adjust if necessary.
6. Special cases: If fastening is done on non-standard walls (e.g., gypsum concrete, timber stud walls), a thorough assessment of how forces are distributed is necessary.
Finally, a tip: To be on the safe side, in addition to the supplied fasteners, use your own high-quality anchors – this usually provides a better sense of security and greater stability.
