ᐅ How reliable is the wall mounting for Ikea PLATSA?
Created on: 30 Oct 2022 14:23
Lira69
I would like to start a discussion on the topic: “How secure is the wall mounting for Ikea Platsa?”
Specifically, I am interested in the typical load capacity of the mounting hardware when installing the units on a standard drywall. My goal is to understand whether the mounting materials provided by Ikea (screws, anchors, brackets) are generally sufficient to securely fix the cabinets over the long term, or if additional measures (different types of anchors, extra reinforcements) would be advisable.
It would also be helpful to hear about experiences regarding how critical it is to strictly follow the included assembly instructions, and which common mistakes should be avoided. I appreciate any tips on how to optimize the stability, especially considering different wall materials!
U
usbla
31 Oct 2022 11:05
lorena schrieb:
Screw length and anchors must be matched to the wall thickness and wall material. Many underestimate the importance here.
This is a crucial point. For drywall, I always use screws at least 50mm (2 inches) long with suitable hollow wall anchors. This combination ensures a secure load fastening within the cavity of the wall.
Additionally: never rely on a single fastening point; multiple points provide better load distribution.
GU-LAU60
31 Oct 2022 13:47
One should also pay attention to the correct positioning of the mounting plates. If they are not installed plumb, the forces will be distributed unevenly, compromising the stability.
RETRAVIS
1 Nov 2022 08:45
Supplementing the previous discussion:
Ikea’s assembly hardware is generally designed to hold securely in solid walls when used correctly. For drywall without additional support, I strongly recommend:
- Using metal hollow wall anchors instead of standard plastic plugs
- Distributing the load across at least two mounting points per module
- Adhering to the maximum load specified in the assembly instructions and not exceeding it
Additionally, alternative solutions include installing extra substructures behind the drywall to improve load-bearing capacity.
Lira69
1 Nov 2022 14:17
usbla schrieb:
Never rely on just one fixing point; multiple points ensure better load distribution.
Thanks to everyone so far for the detailed explanations!
I find this point important: Can anyone specify how many fixing points are advisable for a typical 2-3 meter (6.5-10 feet) long Platsa module on a standard drywall (gypsum board) wall?
Also, does anyone have experience with properly securing these modules to a metal stud wall, or is it better to install an additional wooden batten in that case?
PAREL
1 Nov 2022 18:36
Lira69 schrieb:
Can anyone provide more specific advice on how many fixing points are advisable for a typical 2-3 meter (6.5-9.8 feet) long PLATSA unit on a standard drywall?
For a 2-3 meter (6.5-9.8 feet) wide PLATSA unit, I recommend at least three to four fixing points, ideally located on load-bearing areas. If possible, these should be directly attached to metal or wooden studs.
Lira69 schrieb:
And does anyone have experience with properly fixing the modules on a wall with metal studs, or is it better to install an additional wooden batten there?
Metal studs are often thin and not always strong enough to hang furniture directly. Adding a wooden batten fixed horizontally and screwed into the studs significantly improves stability. This helps to distribute the load more evenly and ensures the screws fasten into solid material.
While this may not be strictly necessary for light loads, it is recommended for heavy or large units.
Ixfu2
2 Nov 2022 09:56
A wooden batten beneath metal studs significantly improves load distribution. Metal studs alone can be too thin – using a batten is advisable.
