ᐅ Why is my IKEA PLATSA drawer sticking after assembly?
Created on: 1 May 2022 08:43
fepiba
fepiba
1 May 2022 08:43
Hello everyone, I recently assembled an IKEA Platsa shelving unit and am using the drawers in it. My problem is that one of the drawers sticks noticeably after assembly, meaning it doesn’t open and close smoothly. In my opinion, the drawer slide is installed correctly, but I still feel some kind of friction or resistance that wasn’t there before. I have already checked whether the drawer is misaligned or if any screws were overtightened, but I didn’t find anything unusual. Can someone explain why the PLATSA drawer is sticking after assembly? Are there any common issues or specific installation tips that should be observed? Thank you in advance for your advice.
toril
1 May 2022 09:12
Typical causes of jamming in IKEA PLATSA drawers are usually mechanical misalignments. First, check whether:
- the runners are exactly parallel to the drawer side panel
- the mounting screws are not overtightened, which can deform the runner
- the plastic rollers on the runners are smooth and free of debris
- the drawer height is correctly adjusted and appropriate for the cabinet height
If the drawer jams only in one spot, it may also be due to skewing caused by uneven load. Precise adjustment of the runners according to the instructions is essential.
bapar
1 May 2022 10:03
I can confirm the points made and would like to add a few details: The PLATSA drawers feature a special insertion system with side-mounted rails and plastic glides. Important notes include:
- The double screw securing the rail to the cabinet body should not be over-tightened, as this can cause the rail to bend slightly and lead to friction.
- The drawer itself has adjustable guide points on the sides that need to be precisely set to ensure smooth running.
- It is also important to relieve the drawer when fully loaded; too much weight can affect the movement.
- The assembly instructions include advice on minimal screw preload and compensating for inaccuracies, which are often overlooked.
Additionally, it is important to determine whether the rail catches on one side or if the entire movement is stiff, as this can indicate different sources of problems.
Rhett
1 May 2022 10:31
Make sure to check that the drawer front is properly aligned and not installed crooked. This is often where the problem lies.
Deandre
1 May 2022 11:02
Additionally, I would recommend loosening all the screws on the slides and completely removing the drawer again. Then realign the slides and tighten the screws gently but firmly. This often helps to eliminate sticking points. If the manual is still available, there is a chapter on drawer adjustment that can be very helpful.
fepiba
1 May 2022 11:27
Thank you for the advice. I have checked the screws and inspected the drawer front for left-right tolerance. The rail at the back of the carcass wood appears slightly bent. Could this be caused by an over-tightened screw? What would you recommend to fix such a deformation without having to redo the entire installation? Is there a way to realign the runner if it is already slightly bent, or is replacing the rail the only solution?
