ᐅ How can I securely install IKEA PLATSA units on drywall partitions?
Created on: 29 Jun 2024 08:11
kinsu
I am currently planning to install IKEA Platsa cabinets in a room with drywall partitions and am facing the challenge of how to mount these relatively heavy pieces of furniture as securely and stably as possible. I am especially interested in which fasteners and installation techniques are recommended to ensure long-lasting load capacity without damaging the drywall or putting too much stress on the cabinet walls.
Does anyone have experience with special wall anchors, reinforcement measures behind the wall, or the use of additional mounting plates? I would also like to know roughly how much weight can be safely supported on a typical drywall with standard stud framing.
Thanks in advance for your help!
bauku
29 Jun 2024 14:07
Hey kinsu,
don’t be intimidated by the wall opening! It’s usually less complicated than you think and definitely worth it, especially if you want to securely install heavy furniture like Platsa.
I once opened up my drywall at one spot and installed a plywood panel for reinforcement. With some basic DIY skills and the right tools, you can get it done in a few hours.
Motivation: securely mounted furniture gives you a lot of safety and prevents damage. Afterward, you can neatly fill and paint the wall – and the furniture will be rock solid.
Don’t worry, give it a try! You can do it!
ju_ren
29 Jun 2024 15:12
Always screw directly into the studs; otherwise, it won’t hold. If you don’t hit the studs, you will need to open the wall and reinforce it. Period.
blapau
29 Jun 2024 16:44
Additionally, when choosing screws, it is advisable to use high-quality chipboard screws with good coating, as they cause less cracking in drywall and provide better grip in wooden studs. For metal studs, you need special sheet metal screws.
Before installation, the load-bearing capacity of the wall should also be checked – if the wall is very old or damaged, reinforcement can make a significant difference.
The combination of precise stud location, appropriate screws, and reinforcement if necessary is the key to secure fastening.
Dilen
30 Jun 2024 07:22
A few technical details that are often overlooked:
- The stud orientation and spacing significantly affect load distribution. For metal studs, anchoring with appropriate self-drilling screws (e.g., TEK-type screws) is recommended.
- The panel behind the wall should be installed as flush as possible with the studs to directly transfer the load.
- Use screws of sufficient length that penetrate at least 40 mm (1.5 inches) into the substrate.
- For larger PLATSA units, it is worthwhile to install mounting brackets in addition to direct wall attachments.
If you like, I can calculate the loads for you if you provide the dimensions and weights.
kinsu
1 Jul 2024 09:35
ju_ren schrieb:
Always screw directly into the studs; otherwise, it won’t hold. If you don’t hit a stud, you’ll have to open the wall and reinforce it. Period.
Thanks for the clear advice! I think I will open the wall and install a plywood panel behind it.
Domau0 schrieb:
If you want to avoid opening the walls at all costs, you could also use a large mounting board on the outside of the wall to support the furniture. But that’s usually not very visually appealing.
Would such a mounting board be more like a lightweight frame solution? I want to keep the look as close to the wall as possible. Would you recommend suspending it from the ceiling or a freestanding solution on the floor if the wall is not meant to carry any load?
benon
1 Jul 2024 11:50
kinsu schrieb:
Could such a mounting plate perhaps be more like a lightweight frame solution? I want to keep it visually as close to the wall as possible. Would you recommend a ceiling suspension or a floor-standing solution if the wall is not meant to be load-bearing?
Hello kinsu, here is my assessment:
A lightweight frame structure made of metal profiles that extends from floor to ceiling is often the most stable solution.
- It transfers the weight directly to the floor and completely relieves the wall
- Pipes or connections behind the wall can be better accommodated this way
- Visually, you can cover it with drywall or plywood panels so that it is hardly noticeable
Ceiling suspensions, on the other hand, are often more complex because they have to bear tensile forces – often the ceiling is not strong enough or the fixing is more complicated.
Personally, I prefer the floor-standing option for heavier furniture, as it is the most reliable.
