ᐅ How can I adapt IKEA PLATSA for use in rental apartments?
Created on: 22 Nov 2023 08:17
maceo
Hello everyone, I’m looking for good ideas and tips on how to adapt the IKEA Platsa system specifically for rental apartments. My main challenge is that many solutions require permanent attachment to walls or structural alterations, which are often not possible or desired in rental properties. Therefore, I’m interested in flexible, removable, and wall-friendly modifications that still provide stability and storage space. Are there clever tricks to modify the system to fit precisely and work practically without drilling or major changes? For example, alternative fastening methods, interior divisions, or additions that improve its use? I look forward to your experiences and suggestions!
Nabla64
22 Nov 2023 12:40
Hello maceo, I’ll give you a step-by-step guide on how to adapt the Platsa system for your rental apartment:
1. Planning: Measure the space carefully, paying attention to ceiling height and any recesses.
2. Module selection: Choose only the necessary modules to keep the weight low and maintain flexibility.
3. Stabilization: Use telescopic poles to support the ceiling. These can be extended in depth or width, avoiding the need to drill into walls.
4. Floor protection: Use felt pads under the furniture legs to prevent scratches.
5. Interior organization: Use boxes, baskets, and drawer inserts strategically—often, IKEA offers just the right accessories.
6. Avoid gluing: Instead of screws, attach individual modules with clamp connectors or lockable plug-in fittings.
7. Cleaning: Apply matte protective films on the back if dirt accumulates on the wall. If you have trouble with unstable connections, I can send you a list of compatible connectors.
andre3
23 Nov 2023 07:52
As a general rule, permanent modifications should always be avoided in rental apartments. For the PLATSA system, I recommend using non-invasive stabilization methods such as reinforced base feet or pressure-fixing telescopic rods, which require no tools or wall attachments. Additionally, storage space can be efficiently utilized with flexible inserts using plastic bins and/or shelf liners. Another idea is to place the modules side by side so they support each other, for example, in an L-shape. This way, you gain more stability without drilling holes.
peovin
23 Nov 2023 09:18
Additionally: There are also Velcro or magnetic solutions that allow you to secure doors and small shelves without using screws. This is helpful if you need to rearrange the modules frequently.
maceo
23 Nov 2023 09:42
Thank you for your feedback! The idea of telescopic poles sounds interesting; I was just concerned whether they would hold well in older apartments with uneven ceilings. Are there special models or tips on how to effectively use them on irregular surfaces? Also, I'm intrigued by the idea of arranging the PLATSA modules in an L-shape – do you have experience with the stability of this setup when no wall fixing is used? The hook-and-loop options for doors sound practical as well, thanks for the suggestion.
Kinbu
23 Nov 2023 10:06
maceo schrieb:
The idea of telescopic poles sounds interesting, but I was concerned about whether they would hold well in older apartments with uneven ceilings.
That’s a valid concern. In cases of uneven ceilings, rubber pads at the ends of the poles or flexible connectors can help compensate for irregularities. If needed, you can also use very thin wooden boards as cushioning shims.
maceo schrieb:
Also, I’m interested in arranging the PLATSA modules in an L-shape – do you have any experience with the stability of this setup, especially without wall mounting?
The L-shape does indeed provide more stability, especially when the modules are connected at the inside corner. Make sure the corner brackets fit securely. The combination of the L-shape and weighted feet effectively reduces the risk of tipping.
Luciandi
23 Nov 2023 11:39
maceo schrieb:
Also, I’m interested in arranging the PLATSA modules in an L-shape – do you have any experience with the stability of this setup when not anchored to a wall?
I feel the same way – at first, I was worried about stability too. An L-shape with two modules securely locked together with sturdy connectors is surprisingly stable, especially when the lower modules serve as a base. The weight and shape provide stability even without wall anchoring.
For uneven walls or ceilings: wooden shims or small felt pads often work wonders to compensate for minor irregularities and help secure the rods better.
