ᐅ Are there any experiences with the durability of IKEA Platsa systems after several years?
Created on: 30 Dec 2024 08:23
farlinusHello everyone, I am planning to purchase an IKEA Platsa wardrobe system for my bedroom, and possibly also for the hallway. Since I place a lot of value on durability and sturdiness, I would like to know in advance: Do you have any experience with the longevity of IKEA Platsa after several years of use? I am especially interested in aspects such as the stability of the construction, material quality (panels, hinges, drawer slides), and whether there are common signs of wear or weak points that appear after 3, 5, or even 10 years. It would also be important to know how the system holds up with frequent use, such as daily opening and closing. Are there perhaps different experiences depending on the location or assembly? Thank you in advance for your detailed opinions and tips!
Hey farlinus! Great question, I really like Platsa and have been using my system for 6 years now! The stability is excellent, I haven’t had any issues with wobbling or anything like that. Of course, the surfaces show some light signs of wear, especially on the edges. But that’s just normal with frequent use. The hinges have lasted a long time, and I haven’t needed to adjust anything so far. If you want, I can share some tips on assembly, which really helps with durability! Overall, it’s definitely a sturdy system that works well in everyday use :-)
There are various user experiences regarding the durability of IKEA Platsa. For typical household use, especially in living rooms or bedrooms, a service life of approximately 5 to 7 years under normal use is considered realistic. From a materials perspective, IKEA mainly uses particleboard with a melamine coating for Platsa. These materials are susceptible to moisture and mechanical impacts but generally do not show significant wear if handled properly. The hinges and drawer slides are standardized metal components that can be easily replaced. Often, the connections using wooden dowels and screws are critical; frequent disassembly can compromise stability.
Hello farlinus, I would like to provide a more detailed response here, as your question about durability and specific material and construction quality perfectly aligns with the parameters I have dealt with in my own projects. The IKEA Platsa system is based on a modular design using 20mm (0.8 inch) thick particle boards coated with melamine resin. This is cost-effective and practical, but over long-term use, the stress on connection points becomes critical. For example, if screws are repeatedly removed and reinserted, the material tends to loosen. Due to the use of wooden dowels in the construction, the fit can also deteriorate over time, which may lead to instability. The hinges are sturdy, and the metal drawer slides continue to function well even after several years; however, under heavy load, slight deformation of the fronts at the corners is possible. It is important that the system is placed on a level surface and that the load is evenly distributed. How intensively do you use the cabinets? Are they heavily loaded or used mainly for clothing? Are there any humid areas in the living space that need to be considered?
