Hello everyone, I have some IKEA Platsa furniture that I no longer want to use for its original purpose, but I also don’t want to just throw it away. Therefore, I’m considering how to best recycle or upcycle the Platsa furniture. Does anyone have specific ideas on how to transform the individual parts (frames, shelves, doors) into new uses? I’m particularly interested in which woodworking modifications make sense, how to disassemble them without damaging the materials, and whether there is any kind of environmentally friendly way to dispose of the leftover pieces. Additionally, I’m curious about how to easily change the typical light-colored furniture surfaces so they look good in new contexts. Thanks in advance for your tips and experiences!
If you encounter difficulties disassembling the units, here is a tip: you can leave the Platsa units as they are and simply enhance them superficially. For example, doors can be easily transformed into multifunctional elements using chalkboard paint or magnetic paint. This way, you create a practical notice board or writing surface without having to take the furniture apart. If dismantling is possible, make sure to deburr the edges lightly with sandpaper to prevent damage during future use. Also, try to keep all screws and fasteners together, as losing mounting hardware will make repurposing the furniture much more difficult later on.
Hello, based on multiple experiences in furniture upcycling, I would like to add the following suggestions: You can create open shelves from individual PLATSA frames by removing the back panels and rearranging the shelves. A simple and attractive transformation is also to visually enhance the often quite plain white surfaces using decoupage techniques or fabric covering. It is important to always check the stability before such work and, if necessary, reinforce with brackets or screws. Offcut pieces can also be useful for household furniture repairs, for example as intermediate shelves for other units or as small platforms.
A structured approach to upcycling PLATSA furniture might look like this: - First, analyze which furniture parts are available (frames, shelves, doors, back panels) - When disassembling, systematically remove screws and make sure to collect all fasteners - Carefully remove panels to avoid damaging the edges; if needed, lightly smooth the edges with sandpaper - Treat surfaces with chalk paint, varnish, or adhesive films for a new design - For new uses: doors can be repurposed as small room dividers, shelf fronts, or even as writing or wall mirrors - Frames can be used as open shelves, while back panels can serve as bulletin boards or magnetic boards - Dispose of leftover materials responsibly through bulky waste collection or local recycling centers Tip: Taking photos along the way helps document the process, making reassembly or modification easier and keeping your options flexible. If anyone needs more details on surface treatment, I’m happy to help.
Thanks in advance for the many practical tips and the clear approach to dismantling! What I haven’t quite figured out yet is how to handle the typical edges and membranes – have any of you ever had problems with sanding them? Or do you have any tricks for removing the membranes as cleanly as possible or refurbishing them? I’m also particularly interested in durable repurposing solutions that are suitable as furniture in damp areas (e.g., bathroom or basement). So far, I haven’t found much on this, so maybe someone here has tips on coatings or protective methods?
praWarre693 Apr 2021 14:39Frase70 schrieb:
What I haven’t quite figured out yet is how to deal with the typical edges and veneers – have any of you ever had problems sanding them?Yes, I know what you mean! The veneers are very thin and wear through quickly when sanding, so it’s better to sand lightly at first and then change the color. Sometimes pieces can tear off, but you can easily hide any uneven spots with filler. For wet rooms, I used a matte water-based clear coat that’s moisture-resistant and dries fast. The important thing is that the wood is clean and dry beforehand, otherwise bubbles can form later. Hope this helps!
Frase70 schrieb:
I am especially interested in long-lasting conversions that can also be used as furniture in damp rooms (e.g., bathroom or basement).I can only recommend treating the surfaces very well with waterproof varnish or sealing them with special oil (marine oil or wood oil). Sometimes I also apply a layer of epoxy resin, which makes everything completely waterproof – but it takes a bit more time and materials. Maybe you’d like to try something like that; it’s definitely worth it for damp rooms! Doors and shelving parts become especially durable this way.
