ᐅ How stable are Ikea PLATSA units when moved around regularly?
Created on: 9 Mar 2024 08:13
Prago
I am considering getting the Ikea Platsa system, but my usage situation is a bit special: I will likely rearrange the furniture regularly because I am redesigning my apartment and want to remain flexible.
My specific question is: How stable are Ikea PLATSA furniture pieces when they are moved and disassembled frequently? Does the stability or fit of the connections deteriorate with repeated assembly and disassembly?
I am particularly interested in the durability of the screw connections, the hinges, and the material itself. Are there users who have assembled and rearranged the furniture multiple times and can share whether the pieces become wobbly or show any damage over time?
I look forward to your experiences and insights. Thanks in advance!
koduga
9 Mar 2024 11:14
I had a Platsa set that I rearranged three times. After the third time, I noticed a slight wobble that made me uneasy. The screws weren’t holding as firmly anymore.
I was also worried about damaging something and felt bad because I actually like the furniture a lot.
My advice: Definitely have spare parts ready and handle the connections carefully. It might be something to consider choosing alternative furniture for the long term if you plan to rearrange frequently.
likuken
9 Mar 2024 11:46
Prago schrieb:
Are there perhaps screws or reinforcements from third-party manufacturers that work especially well with PLATSA?
I can only say this: No, in my opinion IKEA furniture is not designed to be "upgraded" in that way. The drill holes and materials are often too weak for thicker screws or additional connectors.
If you really want more stable connections, you should consider solid wood furniture or at least furniture with a sturdier carcass.
Dopoki
9 Mar 2024 12:25
In practical terms:
- The weak point of the PLATSA system is the thin material of the back panel and the cam locks.
- Repeated assembly and disassembly weaken these parts, especially if the screws are not always positioned very precisely.
- It is important to always install the back panel correctly to improve stability.
Recommendation: If you frequently rearrange, you should plan for minimal structural reinforcement elements to keep the furniture stable in its final position.
BOMILAN
9 Mar 2024 13:11
After multiple renovations, screws and connections tend to become looser. This is unavoidable.
My advice: always check the screws and, if the holes become too large, use small wooden dowels or suitable fillers.
Prago
9 Mar 2024 14:03
likuken schrieb:
If you really want stronger joints, you should consider solid wood furniture or at least pieces with a more robust carcass.
That’s clear, but sometimes you have to think economically, and Ikea is simply affordable. That’s why I’m specifically interested in how well furniture in this price range holds up to being moved around repeatedly.
Dopoki schrieb:
Recommendation: If you move furniture frequently, you should plan for some minimal structural reinforcement to keep the piece stable in its final position.
Could you explain a bit more about what you mean? Which elements are those exactly? Thanks!
Dopoki
9 Mar 2024 14:43
Prago schrieb:
Could you clarify what exactly you mean? Which elements are you referring to?
Certainly:
- Metal brackets or angle brackets (L-brackets) that can be installed inside the corners
- Additional screws on the interior walls of the modules
- Reinforcement using fixed shelving boards that prevent twisting
This noticeably increases stability, provided the drilled holes are still intact.
