ᐅ How can Ikea HEMNES furniture be assembled more securely?
Created on: 3 Jan 2023 08:36
Bueddie
Bueddie
3 Jan 2023 08:36
Hello everyone, I would like to start a discussion with the specific question: How can Ikea Hemnes furniture be assembled or modified to significantly improve its stability?
My goal is to make the construction more robust because with my Hemnes dressers and cabinets, especially with frequent use or heavier loads, the furniture tends to become a bit wobbly over time.
I have already tried some steps, such as adding extra screws or brackets, but I want to gather the best methods and tips that are possible without overly complex modifications.
Are there any proven tricks, special materials, or techniques to assemble or retrofit the furniture more securely? Thanks for your experiences and suggestions!
Marlenepa
3 Jan 2023 09:47
Hello Bueddie, that’s a good and very precise question!
With Ikea HEMNES furniture, the typical issue is that the construction, made of solid wood with plywood back panels, is stable but often not stiff enough. Here are a few general tips that I always recommend:
- Always use the original dowels completely and ensure they fit tightly.
- Make sure to install the back panels cleanly and fully over the entire surface, as they provide most of the stability.
- Where possible, add extra metal brackets inside, for example in corners or under the furniture.
- For cabinets: be sure to also fix the back panel at the bottom, not just at the top and sides.
- Always tighten screws with enough torque but not too much to avoid damaging the wood.
If you like, I can also provide examples of screw types and exact positions!
todunar
3 Jan 2023 10:52
Hey Bueddie, great topic! I’ve also always felt that the HEMNES furniture could use a bit more stability.
What really helped me was placing small rubber pads or felt gliders under the furniture—not just to protect the floor, but also to even out minor unevenness, which makes the furniture stand more firmly and prevents wobbling.
Additionally, I installed small flat metal corner brackets inside my dressers. They make a big difference and are very affordable!
Important: Always check step by step to make sure everything is tightly secured; otherwise, even good reinforcement won’t help much!
boelnu
3 Jan 2023 12:03
Hello!
I completely understand how frustrating that wobbly feeling can be when you expect sturdy furniture. I had a similar experience with my HEMNES bed frame.
One thing I learned is to check the supplied screws and wall plugs to make sure they are actually strong enough—sometimes they are a bit smaller or thinner than ideal.
Also, what helped me, especially with heavily loaded furniture like cabinets, was adding extra cross braces inside the sides. To keep them discreet, I used thinner wooden boards and mounted them out of sight on the inside.
It does require some DIY skills, but the cabinet definitely becomes more stable afterward.
How about you, Bueddie? Do you also use reinforcements like these?
Bueddie
3 Jan 2023 14:27
Marlenepa schrieb:
Always install the back panels carefully and fully across the entire surface, as they provide most of the stability.
That’s an important point, thanks! I have actually sometimes screwed the back panel in a bit loosely because I thought the wall plugs would be enough.
todunar schrieb:
Installed small metal corner brackets (the flat kind). They really make a big difference and are super cheap!
That sounds practical and simple, exactly what I’m looking for.
boelnu schrieb:
Especially for heavily loaded furniture like cabinets, attach additional cross braces inside on the sides.
I haven’t done that yet, but I’m wondering if you could possibly install these cross braces at a slight angle to better prevent sideways wobbling.
Has anyone here had experience with that?
O
olivernu
4 Jan 2023 07:15
To prevent lateral wobbling, I recommend installing diagonal braces on the back or inside the frame. An angled beam distributes forces more effectively and significantly increases stability.
Before retrofitting, it should be checked whether the furniture is actually attached to the wall. The HEMNES series offers compatible wall mounts – these are not only safer but also reduce considerable movement in the structure itself.
Another tip: For drawer dressers, adding additional guide rails can help to keep the structure together.
These measures require some basic DIY skills but are generally feasible and very effective.
