ᐅ Are there IKEA PLATSA furniture units with integrated handle strips?
Created on: 29 Jul 2017 08:47
Darragh
Hello everyone, I recently looked into the IKEA PLATSA series and I’m wondering if it’s possible to equip these furniture units with integrated handle strips? I noticed that many IKEA kitchen and furniture series offer handle strips as a practical and stylish solution, but the PLATSA models didn’t seem very clear in this regard. I would like to know if there are official PLATSA units with built-in handle strips or at least a compatible option from IKEA to retrofit them. If not, it would also be interesting to hear if other users here have experience with alternative solutions. Thanks for your detailed answers!
I installed some PLATSA shelves at home with handle strips—but not IKEA strips, rather aluminum profiles I bought myself from the hardware store. It works well, looks neat, and isn’t expensive. If you enjoy some DIY, this can also help you create a more unique style.
Of course, it’s not from IKEA, and you need to measure everything carefully, but if you like handle strips, PLATSA is a good basic framework for ideas like this.
Maybe this will inspire someone who’s considering doing it themselves.
PIN66 schrieb:
By the way: What type of handle strips are you considering? Aluminum, plastic, or wood? Each option has different advantages regarding durability, appearance, and installation effort.Thank you for the detailed response. I was mainly thinking about aluminum handle strips because I find them visually appealing, and they would fit better in my apartment. Wood would be a secondary option, plastic less so, as I often find those to look too cheap. Your tips regarding installation and front panel thickness are very helpful for making a decision. Has anyone tried aluminum handle strips with PLATSA before? Are there any particular features or frequent issues to be aware of?
Darragh schrieb:
Has anyone tried using aluminum handle strips with PLATSA? Are there any special considerations or common issues?There are a few points to keep in mind when working with aluminum strips:
- Precise drilling is essential, as aluminum profiles require fairly rigid mounting.
- With PLATSA fronts, there is a risk of the material breaking out at the drilling points, so pilot holes should be drilled.
- When using screws, make sure that they are not too long and do not penetrate through the front panel.
If you follow these guidelines, it usually works without issues. Some users also apply construction adhesive or double-sided mounting tape to secure the strips further and reduce vibrations.
In my opinion, these are not insurmountable challenges, but careful preparation is necessary to ensure the appearance and functionality are maintained over time.
Darragh schrieb:
Has anyone tried using aluminum handle strips with PLATSA before? Are there any special considerations or common issues?It’s interesting that you specifically want aluminum. The thing is, since PLATSA furniture isn’t designed for this kind of profiling, you should consider whether you might end up damaging the appearance or impairing the function of the furniture—at least without professional modifications.
So far, I’ve only seen examples where the strips were either simply glued on or, which I find more problematic, screws were drilled into the fronts that aren’t actually designed for this purpose. So yes, there are often issues.
Whether it’s worth the risk is a personal decision. That’s why I recommend sticking to series or manufacturers that are designed for handle strips.
