Hello everyone, I have a problem with the back panel of my Ikea Platsa wardrobe. The back panel has partially come loose and overall feels quite unstable, especially at the corners. Since I want to modify the wardrobe a bit, I am wondering: what is the best way to fix or replace the back panel in the PLATSA system without compromising stability? Are there alternative materials or methods that are better suited than the original back panels? I would appreciate specific tips on fastening options, suitable replacement materials, or experiences with custom-made solutions.
The stability of the cabinet mainly comes from gluing the side panels together, while the back panel resists shear forces. Small nails serve only as additional reinforcement. If you want sturdier back panels, you can use 3mm MDF boards and attach them to the back with small screws. The screws should sit flush to avoid dents in the cabinet.
Thank you for the tips regarding the material and fastening. I am also considering whether to completely replace the back panel, as I have the cabinet in a kitchen with conditions similar to a wet room. Does anyone have experience with back panels that are more moisture resistant than the original material?
Regarding moisture-resistant back panels for Ikea PLATSA: Here are my tips. First, a brief summary of the issue: The original back panels are usually made of thin hardboard, which absorbs moisture and can warp. For kitchens or more humid areas, I recommend:
- Using coated MDF panels that are water-repellent
- Alternatively, plywood panels with appropriate sealing
- Sealing the edges with waterproof varnish before installation
- Using screws or small brackets instead of just nails to secure the back panel more firmly
Additionally, you can apply silicone at contact points to help prevent moisture. Make sure the panel is cut precisely to avoid any movement.
In addition to naujon’s suggestions: if you want to replace the back panel, it’s best to measure the existing back panel very precisely and look for a suitable material at the hardware store. Often, 3mm (1/8 inch) MDF boards are used.
For attaching my PLATSA back panel, I used screws with the smallest possible washers to avoid crushing the material. The nails from the IKEA pack hold, but if you have more load, screws are better.
I also recommend not only fixing at the corners but also adding a few attachment points in the middle of the wider sides.
Leonardteo29 Jan 2021 09:49PAR63 schrieb:
I also recommend not only fixing at the corners but adding a few attachment points in the middle of the wider sides.That’s a very good tip. Especially for larger cabinet units, additional fastenings in the middle of the back panel significantly reduce twisting. This principle generally applies in furniture construction: the more fixing points, the less movement.
