ᐅ What should I do if the IKEA PLATSA wardrobe doesn’t fit?
Created on: 4 Feb 2019 09:17
Bomin5
Hello everyone, I am currently assembling my new IKEA Platsa wardrobe, but I’m noticing that it doesn’t fit as I had expected. According to the plans, the dimensions are correct, but due to structural details in the room—like slightly uneven walls and the radiator—the whole layout no longer works. My question is: What can I do if the IKEA Platsa wardrobe doesn’t fit? Are there practical solutions to still use the furniture, or do I need to completely redesign the plan? I look forward to your experiences and advice!
GAGRAHAM
4 Feb 2019 12:45
Bomin5 schrieb:
Using wooden strips as spacers. Could you explain a bit more precisely how you did that?
Sure, happy to! I simply cut narrow wooden strips to exactly match the gap between the back of the cabinet and the slanted wall. I attached the strips to the back panel of the cabinet with small screws so the cabinet stands slightly away from the wall. This keeps it stable because the strips absorb the pressure. The important thing is that the strips are firmly secured and don’t allow any wobbling – it holds very well! 😊
reoWilhelm
5 Feb 2019 08:02
Hello! I also had a case where the Platsa cabinet bumped into a small radiator. The solution was to buy a matching cover panel and place it between the cabinet and the radiator. It looks good and protects the wall. Paying attention to details like this is worth the effort for the next piece of furniture – sometimes you really have to be creative, but that’s what makes a good product: adaptability! ?
GLAEL
5 Feb 2019 09:37
If the dimensions differ significantly, it can also help to replace individual modules or choose a cabinet with a different depth. This increases the chances of a better fit.
Bomin5
6 Feb 2019 10:15
Joshbe schrieb:
The IKEA system certainly offers some flexibility here, but for larger deviations, custom-built fixtures or adjustments by a carpenter are preferable.
Interesting point, thanks! I am actually considering whether to contact a carpenter for perfectly fitting doors/covers. Has anyone had experience with whether this is still economical, or is it better to completely redesign PLATSA in the IKEA planner?
GiRoyce
6 Feb 2019 11:50
That completely depends on how complex the customization is. If you only have a few panels or doors custom-made, it can be more cost-effective than redesigning everything from scratch. On the other hand, the flexible PLATSA modules are easy to combine, so sometimes rearranging with different depth or width models can solve the problem without expensive carpentry work. I would first test different options using the Ikea configurator or with the consulting team, and at the same time request quotes for the carpentry costs.
