ᐅ What should I do if the IKEA PLATSA wardrobe doesn’t fit?
Created on: 4 Feb 2019 09:17
Bomin5
Bomin5
4 Feb 2019 09:17
Hello everyone, I am currently assembling my new IKEA Platsa wardrobe, but I’m noticing that it doesn’t fit as I had expected. According to the plans, the dimensions are correct, but due to structural details in the room—like slightly uneven walls and the radiator—the whole layout no longer works. My question is: What can I do if the IKEA Platsa wardrobe doesn’t fit? Are there practical solutions to still use the furniture, or do I need to completely redesign the plan? I look forward to your experiences and advice!
GiRoyce
4 Feb 2019 09:45
Hello Bomin5, your situation is quite common since PLATSA is modular, but the structural details often make it difficult to fit everything perfectly. If you say the cabinet doesn’t fit, I would first recommend measuring the exact space again—including even the smallest dimensions—and possibly checking how uneven the wall is with a level. Sometimes it also helps to swap individual modules or assemble only partial components to make better use of the space. Alternatively, you can adjust the frame on the sides using angle brackets or custom fittings, or cover small gaps with panels.
GAGRAHAM
4 Feb 2019 10:13
Hey, great question! 😊 I had the exact same problem and solved it like this: I built the cabinet slightly offset and cushioned it with small wooden strips. You can easily compensate for angled walls with tricks like these! Even if it sounds complicated at first—you can do it! 💪 PLATSA is so flexible, there’s always a solution. Don’t get discouraged, it will work out!
gauvin37
4 Feb 2019 10:46
If the cabinet doesn’t fit, first check the wall angles and measurements. Trim parts if necessary or use flexible modules. Radiators can be bypassed with covers.
Joshbe
4 Feb 2019 11:30
Regarding the issue of unsuitable furniture in rooms with non-standard dimensions: A possible approach is to precisely measure all relevant surfaces, including wall diagonals and window/door heights. Afterwards, you should check which PLATSA modules can be combined and, if necessary, adjust surrounding areas with panels or spacers. The IKEA system does offer some flexibility, but custom-built installations or modifications by a carpenter are preferable for significant deviations. When in doubt, consulting with IKEA staff can be worthwhile, as they sometimes offer special orders or specific solutions.
Bomin5
4 Feb 2019 12:07
That sounds interesting, using wooden strips as spacers. Could you explain in more detail how you did this? Were there any issues with stability? I would prefer not to compromise the overall construction’s stability, as it needs to be secure.
