ᐅ How can I retrofit or replace Ikea PLATSA doors?
Created on: 17 Jul 2023 09:12
rayan
Hello everyone, I currently have an Ikea Platsa shelving unit without doors, but I would like to retrofit doors or replace the existing ones if that makes more sense. My specific question is: How can I add or replace Ikea PLATSA doors without dismantling the entire system? Are there compatible doors from Ikea or third-party suppliers, and how exactly does the installation work technically—for example, attachment points, hinges, and dimensions? I want to make sure the doors are securely mounted and look good. I am also interested in whether there are alternative, perhaps more flexible solutions to attach or swap doors. Thanks in advance for your advice!
Gafiel
18 Jul 2023 08:17
I would like to go into more detail: When retrofitting or replacing Ikea Platsa doors, the following technical details are crucial. First: The holes for the hinges are standardized and arranged in a pattern with 37 mm (1.5 inches) spacing vertically from the bottom of the cabinet. If your shelf sides do not have pre-drilled holes, you must drill them with utmost precision. It is best to use a drilling template for 35 mm (1.4 inches) fittings to place the hinges correctly. The hinges themselves have a 35 mm (1.4 inches) diameter and are fixed with two screws – each hinge can support a load of about 3–4 kg (6.6–8.8 lbs), so for larger doors, be sure to install two hinges. I also recommend using original PLATSA doors for retrofitting because alternatives often lack the important ventilation groove on the bottom edge of the door – this groove ensures air circulation, especially for closed cabinets over extended periods. One more tip: The door angles must be adjusted precisely; otherwise, the doors may jam or not close properly. The hinges have adjustment screws for horizontal, vertical, and depth alignment.
rayan
18 Jul 2023 11:02
Gafiel schrieb:
When retrofitting or replacing Ikea PLATSA doors, the following technical details are crucial.
Thank you for the note about the 37mm (1.5 inch) hole spacing; I wasn’t aware of that, and it might explain why other doors didn’t fit.
One more question: If I buy new doors, can I keep the existing hinges, or should I replace them as well? I want to avoid changing parts unnecessarily, but if the old hinges are not compatible, that would obviously be pointless.
JONSON
18 Jul 2023 12:45
rayan schrieb:
If I buy new doors, can I keep the existing hinges or should I replace them as well?
In general, you can reuse the existing hinges as long as they are not damaged or warped. Most PLATSA doors are designed for standard hinges, so they should be compatible. However, you should always check this before purchasing. If the doors are from a different model year, there might be slight differences—in that case, a complete replacement might be worthwhile.
kasan
18 Jul 2023 15:00
KAUDRA62 schrieb:
Third-party suppliers? They exist, but you have to pay close attention to dimensions and hinge positions, otherwise it won’t work out.
I would like to add a critical note: Many third-party doors may seem like more affordable or stylish options, but without official measurements from Ikea or precise custom fitting, this can quickly turn into a bad investment. Especially in furniture, it’s important to focus on exact fit and material quality; otherwise, not only the appearance but also the durability will suffer.
I am skeptical whether the effort is worthwhile unless you are planning a complete custom build with adjusted fittings.
A question for the community: Do you have any experience with custom doors (e.g., made-to-measure or with different hardware) as an alternative to the Ikea set?
KAUDRA62
18 Jul 2023 17:35
kasan schrieb:
A question for the community: Do you have experience with custom doors (e.g., made to measure or with different fittings) as an alternative to the Ikea set?
Hey kasan, yes, I once fitted a PLATSA shelving unit with custom-made wooden doors because I found the Ikea fronts too plain. It was important to pre-drill the hinge holes precisely or to use compatible mounting plates. The doors were made by a carpenter, using standard fittings (35 mm hole system) – that worked perfectly. The main challenge was getting the door thickness right so the hinges would function smoothly. So, for DIY enthusiasts, it’s definitely doable, but without proper technical preparation and exact measurements, it can get tricky. Your Ikea PLATSA will turn into a unique piece, which is really fun!
rayan
19 Jul 2023 08:54
Great, thank you all for the valuable information! To summarize, I now understand:
- I should carefully check the dimensions of my PLATSA module (W x H x D).
- Original IKEA doors are the safest option because they have the correct hole spacing.
- I can usually reuse the hinges if they are in good condition.
- If holes are missing, I should carefully drill them myself or try alternative solutions.
- For custom fronts, precision in drilling and using the 35mm hinge cup standard is essential.
I will start with the original doors and make adjustments if needed. Thanks also for the tip about the ventilation groove; I hadn’t considered that. If anyone has advice on the best tools for precise drilling, I’d appreciate it!
