ᐅ Is it possible to equip IKEA PLATSA doors with soft-close hinges?
Created on: 5 Feb 2024 10:07
Brintan
Brintan
5 Feb 2024 10:07
Hello everyone, I currently have PLATSA cabinets from IKEA at home and am considering adding soft-close hinges to the doors. My specific question is: Is there a way to retrofit the existing PLATSA doors so that they close gently and quietly, meaning they get a soft-close function? If yes, which hinges or mechanisms are compatible and what should I keep in mind? I would prefer not to replace entire doors or remodel the cabinet but rather find a practical retrofit solution. Thanks in advance for your experiences and expert advice!
kieran
5 Feb 2024 10:23
The PLATSA series from IKEA comes standard with basic pivot hinges that do not include a soft-close feature. Retrofitting is generally possible, but it is important to know:
- IKEA currently does not offer original soft-close hinges for PLATSA.
- There are universal soft-close dampers that can be added, but mounting brackets and spacing need to be carefully checked.
- Alternatively, the existing hinges can be completely replaced, for example with compatible soft-close hinges from third-party suppliers – though this typically requires more extensive modifications.
My advice: Before purchasing such dampers, measure the dimensions of the door and the cabinet precisely to ensure the mechanism does not interfere with the cabinet or function improperly.
narDietmar
5 Feb 2024 11:11
There are actually retrofit kits specifically designed for IKEA furniture to add soft-close functionality. However, with PLATSA, the way the doors are attached is special, so not all soft-close hinge solutions fit.
A working workaround is to attach soft-close dampers separately to the hinges or directly to the cabinet frame. This must be done with technical precision to ensure the mechanism functions properly.
In general: the prefabricated hinges for PLATSA do not have built-in soft-close functionality. Retrofitting is possible but requires considerable effort.
Mufato
5 Feb 2024 11:52
You can add soft-close dampers to the existing hinges. Completely replacing the hinges is difficult because the drill holes for PLATSA are different. A simpler solution is to try clamping the damper to the cabinet frame.
mauka
5 Feb 2024 12:17
So, I equipped my PLATSA doors with soft-close dampers from the hardware store – no rocket science! Sure, installing them is a bit fiddly, but the difference is huge. The doors don’t slam anymore and close smoothly. The important thing is not to just use any dampers, but to position them carefully. I recommend keeping the hinges open and attaching the dampers inside the cabinet, which keeps everything stable and looks neat 🙂
kieran
5 Feb 2024 13:02
mauka schrieb:
So, I fitted my PLATSA doors with soft-close dampers from the hardware store – nothing complicated! Sure, the installation is a bit fiddly, but the difference is huge.
This practical experience confirms that retrofitting with dampers is worthwhile. But be careful: the positioning of the dampers must be precise to avoid permanent damage. For long-term performance, using high-quality branded products is recommended.
