ᐅ How do you install Ikea Pax wardrobes in bathrooms?
Created on: 3 Jun 2016 08:13
pinsi
Hello everyone, I am planning to install an Ikea Pax wardrobe in my bathroom. However, I am facing some specific challenges because the bathroom has limited space and is affected by moisture as well as uneven walls. My main question is: What tips and techniques should be considered when assembling an Ikea Pax wardrobe in a bathroom, especially regarding moisture protection, mounting on tiled walls, and possible stability issues due to the humid environment? Are there any practical experiences or modifications to the assembly process that have proven effective specifically for bathrooms? I would appreciate a detailed response with possible additional solutions.
U
usteto
3 Jun 2016 12:45
The back panels of Ikea Pax wardrobes are thin and not water-resistant. At the time, I replaced the back panel with a thin water-resistant MDF board and treated it with paint. This ensured stability and better protection of the material against moisture.
Issac_kla2
3 Jun 2016 13:30
pinsi schrieb:
I would like to clarify something: The bathroom mostly has smooth, large-format tiles, and the walls are not completely straight—they slope slightly toward the shower.
It sounds like an Ikea Pax wardrobe might not be the best choice for such a damp and uneven area. Who needs standard particleboard furniture when the number one moisture enemy is right at the door? Sure, with sealing and tricks you can get pretty far, but in the end, it’s like fighting a losing battle. Honestly, a specialist cabinet that truly meets wet room standards might be a better option, right?
harold
3 Jun 2016 15:12
Issac_kla2 schrieb:
That sounds like an Ikea Pax wardrobe might not be the best choice for such a damp and uneven area.
This can be true in some cases, but it doesn’t automatically mean that Pax is unsuitable. With the right preparations and protective measures, the wardrobe can be adapted quite well.
Regarding back panels: there are special waterproof boards that can be cut to size – as usteto already mentioned, MDF with a lacquer coating or even rigid foam boards as an alternative. This eliminates the problem of swelling back panels.
It is always important to ensure that no water accumulates around the connection points during installation, so everything should be sealed properly. It is also advisable to install the wardrobe units with a gap from the wall side wet zone.
For uneven walls, I can only recommend again using washers or spacer shims, which help to compensate for irregularities and align the wardrobe properly.
lubla
4 Jun 2016 07:48
I placed rubber pads under the feet of my bathroom Pax cabinet and replaced the back panel with a waterproof layer. It is also important to secure the doors with additional magnetic catches to prevent warping.
fidasi
4 Jun 2016 09:03
harold schrieb:
Regarding back panels: There are special waterproof boards that can be cut to size—like usteto already mentioned, MDF with a coating or even rigid foam boards as alternatives.
To revisit the topic of back panels: rigid foam boards are actually the best choice for damp environments. They are lightweight, waterproof, and easy to saw and customize.
For moisture protection, I recommend applying special sealing tape to all contact surfaces, including the back of the cabinet back panel, before installation. This prevents moisture from penetrating the wood-based materials. Also, make sure to maintain a gap to protect against floor moisture—this can be done by using adjustable feet or spacer blocks.
I’m curious about the exact slope of your bathroom wall toward the shower, as that might help offer even better installation advice. Have you measured it?
