ᐅ How can I modify Ikea Pax wardrobes to improve air circulation?
Created on: 28 Apr 2018 17:07
DanieldaHello everyone,
some time ago, I bought an Ikea Pax wardrobe and noticed that the air circulation inside is rather poor. Especially with clothing hanging low and in the lower sections with closed fronts, the air hardly seems to refresh. I am interested in how to modify the Pax wardrobe to improve air circulation without compromising stability or appearance too much. Do you have experience with modifications such as adding ventilation holes, replacing certain panels, or perhaps installing small fans? Any advice on materials or alternative solutions is also welcome. Thanks in advance!
The Ikea Pax is not originally designed for high air circulation, so modifications are necessary if ventilation is a concern. Here are some practical suggestions:
- Drill holes or ventilation openings in the back panel, preferably near the top and bottom to improve convection.
- Replace the back panel with a perforated or breathable version, such as pegboard or a thin mesh.
- Create small gaps of about 1 cm (0.4 inches) between shelves to allow horizontal air circulation.
- Optional: Install small, quiet fans at the back, powered by a low-consumption power supply.
These options significantly enhance airflow without noticeably compromising structural stability. Important: The holes should be carefully positioned to avoid affecting load-bearing capacity and appearance too much.
I have done this myself and think it is important to consider a few things beforehand:
- When drilling the back panel, be careful not to compromise the stability. The back panel also serves to stabilize the entire structure.
- For example, you can replace the central back panels with a perforated metal or wooden sheet with holes, which can be found at hardware stores.
- I have also had good experiences using small ventilation grilles, like those used in ventilation systems, which can be attached to cut-out sections.
This significantly improves airflow, especially when ventilating from both the bottom and top.
From a technical perspective, there are several details to consider when modifying the Pax for improved air circulation.
First, the back panel is usually made from thin hardboard material, which significantly contributes to the overall stability of the cabinet. Completely removing the back panel is therefore counterproductive. A better approach is partial replacement, for example by exchanging individual segments.
It is advisable to fit the lower and upper sections of the back panel with perforated metal or plastic sheets. These should be corrosion-resistant if possible. The holes should be approximately 0.5–1 cm (0.2–0.4 inches) in diameter to allow sufficient airflow. Positioning holes at the bottom enables cool air to enter, while the holes at the top allow warmer air to escape (convection).
It should be noted that adding spacing between shelves—using blocks or spacer strips, for example—improves horizontal air circulation. However, these gaps should not be too large to avoid creating excessive openings or compromising stability.
Another more complex option is installing a quiet, small fan on the upper back part, powered via USB or low voltage. The airflow, however, should not be directed straight onto delicate textiles, as this may dry out or deform fabrics.
One more tip: during planning, ensure the modifications are not visually disturbing from the inside. Ideally, use subtle solutions without visible grilles on the outside or holes in the front panels.
If more information about the existing setup or material preferences is needed, feel free to ask specifically.
mintra schrieb:
- Make holes or air vents in the back panel, preferably in the upper and lower areas for better convection.That sounds interesting, but wouldn’t drilling holes in the back panel affect the stability? It’s important to me that my cabinet doesn’t become wobbly.
kulau schrieb:
Completely removing the back panel is therefore counterproductive. It’s better to partially replace it by swapping out individual sections, for example.Could you explain in more detail what such partial sections might look like and how to best secure them? I just took another look at the back panel – it consists of several thin boards, right? Thanks in advance!
