ᐅ Are there Ikea Pax fastening systems suitable for rental apartments?
Created on: 22 May 2021 14:03
amirus
Hello everyone, I will soon be moving into a rental apartment and plan to use my Ikea Pax wardrobe there. However, I am unsure how to secure it without causing damage to the apartment. Are there specific Ikea Pax mounting systems or solutions that are especially suitable for rental units, meaning no direct drilling or screwing into the walls? I would appreciate practical experiences, recommendations, or advice on how to safely fix the wardrobe so that it stands firmly and is not a safety hazard, but can also be easily and cleanly removed without leaving marks. Thanks in advance!
flo-Theres
23 May 2021 09:37
From a technical standpoint, the original wall anchors provided by Ikea for the Pax wardrobe are safer than temporary fastenings. However, I understand the need to be cautious in rental apartments. Tension rods are a proven solution if properly installed and if the ceiling is suitable. Be sure to check the load-bearing capacity and use protective pads to prevent damage. Alternative clamp profiles can sometimes be gently fixed using construction adhesive or strong tapes, but one should be cautious regarding load and stability in these cases.
V
Victor54
23 May 2021 11:05
vinli schrieb:
Ikea itself generally provides mounting hardware for securing the Pax wardrobe to the wall.
That is correct, but I would add that this method is often not feasible in rental apartments because landlords usually do not allow drilling holes.
meoreo schrieb:
In rental apartments where drilling is not an option, tension rods or clamp profiles often work.
That is true, but I view it with some caution: tension rods apply pressure to both the ceiling and the floor, which can cause damage, especially in older buildings or on delicate surfaces. Whether this is truly tenant-friendly depends on the individual case. Before using such solutions, it is advisable to discuss them with the landlord or property management.
Therefore, I recommend thoroughly checking in advance what is permitted and whether alternatives like self-adhesive furniture anchors could be suitable—although these are less effective for larger wardrobes such as the Pax.
Naomige
23 May 2021 13:25
Hello amirus, I’d like to support you since I’m in a similar situation and have researched this topic thoroughly. There are different ways to securely fix Ikea Pax wardrobes in rental apartments, but a few points should be considered:
- Ikea provides mounting hardware that requires drilling, which is usually not allowed in rental apartments.
- Tension rods, as mentioned earlier, are a popular alternative. They work best when the ceiling height is measured precisely and the ceiling is sturdy.
- To avoid damage, it’s best to use rubberized ends or soft pads where the rods make contact.
- There are also magnetic or self-adhesive mounts, but these are generally unsuitable for heavy furniture like Pax.
- Some tenants position the wardrobe between two solid walls, which provides stability without drilling.
In summary: Original Ikea mounting hardware is not specifically designed for rental apartments where drilling is not allowed. Other systems, like tension rods, often work well but are not official Ikea products, so you should carefully check whether they could cause any damage.
amirus
24 May 2021 10:11
Naomige schrieb:
There are different ways to securely fix Ikea Pax wardrobes in rental apartments, but a few things should be considered:
Thank you for the detailed summary! The idea of rubberized ends on tension rods sounds very sensible; I will look into that more closely.
Victor54 schrieb:
Therefore, I recommend checking in advance what is allowed and whether solutions like self-adhesive cabinet stabilizers might be an alternative
Unfortunately, my landlord does not allow drilling, but I have also heard about these cabinet stabilizers. In your opinion, are they really not stable enough for a heavily loaded Pax?
Also, I wonder if it might be possible to combine methods—e.g., self-adhesive stabilizers plus tension rods for additional tipping protection. Has anyone had experience with that?
V
vinli
24 May 2021 11:06
amirus schrieb:
Do you really think they are not stable enough for a heavily loaded Pax wardrobe?
Self-adhesive cabinet stabilizers can help with light furniture, but they are not reliable enough for the load and height of a fully loaded Pax wardrobe. The risk of the wardrobe tipping over remains too high.
amirus schrieb:
whether it might be possible to combine them – for example, self-adhesive fasteners plus tension rods to prevent tipping.
A combination can make sense, yes, provided the tension rods are properly secured and firmly installed. The self-adhesive parts take some of the load but are not a replacement for mechanical fixing. In practice, tension rods usually need to serve as the main fixing method.
