ᐅ How can I assemble a large Ikea Pax wardrobe by myself?
Created on: 3 Feb 2023 10:13
Reda42
Reda42
3 Feb 2023 10:13
Hello everyone, I am currently facing the challenge of assembling a large Ikea Pax wardrobe entirely on my own. Since I don’t have any helpers available, I am looking for a suitable strategy or tips on how to efficiently and safely put together this wardrobe without assistance. I have a general idea of the instructions, but I am particularly concerned about handling the large side panels and doors. Are there any techniques, well-suited tools, or helpful workflows that can make the process easier? I am especially interested in how to build the wardrobe securely while keeping all components properly aligned without anyone lending a hand. Thanks for your help!
barda6
3 Feb 2023 10:54
It is best to use clamp vices to temporarily secure large components. Doors should be installed last, as they can get in the way while working. Follow the instructions step by step and try to assemble everything on as level a surface as possible.
Surela
3 Feb 2023 13:27
Regarding your question about assembling a large Ikea Pax wardrobe on your own, I would like to add that it’s important to divide the assembly into logical stages. I recommend first laying out and grouping all the individual parts to keep an overview. Then, start by assembling only the main frame using the side panels and the bottom/top panels. It can be helpful to use angled clamps to hold the side panels together and prevent slipping.
An important detail is alignment: use a spirit level to ensure the frame is standing straight. Especially when assembling alone, temporary fixings are crucial to keep components in place. Attach the doors and drawers only at the end because they can otherwise obstruct access to the interior.
I would also like to know if you have a cordless drill available, as this significantly simplifies screwing tasks and saves time. Additionally, I recommend installing the large back panels as late as possible, since they reduce flexibility during assembly.
Do you plan to assemble the entire wardrobe within one room, or do you want to build parts in their intended space? This greatly affects how you manage the process.
Reda42
3 Feb 2023 14:41
Surela schrieb:
I would also like to know if you have a cordless drill/driver available, as that makes the screwing tasks much easier and saves time.
Thank you for the detailed advice! Yes, I do have a cordless drill/driver, so that should work well. I’m assembling the cabinet entirely in the living room, where I have enough space on a level floor. As you recommend, I plan to attach the back panel later. Using clamps to hold it in place sounds very practical, but I’ve never worked with them for furniture before. Is there a specific technique or size of clamps you would recommend?
Also, I’m wondering if I should lean or support the parts a bit when attaching the side panels alone, or is that too risky without a second person?
tra_nina
3 Feb 2023 15:07
When handling the large side panels of the Pax wardrobe, I recommend stable support against a wall or furniture to control the weight. Ensure the components are firmly positioned to prevent tipping. Clamps at least 10cm (4 inches) wide provide good grip; quick-release models are especially convenient.
Using a cordless screwdriver is appropriate; use an adjustable torque setting to avoid overtightening screws. Follow a logical assembly sequence: first attach the bottom and top panels, then secure the side panels.
Regarding leaning the panels: yes, it is possible, but avoid relying solely on soft or smooth surfaces for support, as this increases the risk of slipping. A combination of leaning and clamping is ideal.
peovin
3 Feb 2023 15:53
I would also recommend mounting it on the wall. Attach the wall fasteners early on, so you can secure the cabinet later to prevent it from tipping over. If the side panels are very heavy, you should lean the panels against the wall and secure them with clamps before installing the bottom and top parts.
