ᐅ How do you properly clean IKEA PAX doors with a laminate finish?
Created on: 3 Apr 2024 10:12
Eldaman
Eldaman
3 Apr 2024 10:12
I have a question about cleaning Ikea Pax doors with a foil finish. My doors have a matte foil coating, and I want to clean them as gently and effectively as possible without damaging the surface or leaving unsightly streaks. Since the foil can be delicate, I’m wondering which cleaning products and methods are truly optimal. Is it okay to use standard glass cleaners, or are mild soap solutions better? And what about microfiber cloths – are there differences in quality or suitability? I want to avoid wearing down or scratching the foil.
Maybe someone here has practical experience with care tips and recommendations beyond the general advice from Ikea? I’m looking forward to your suggestions and tips!
loken
3 Apr 2024 10:35
Hey Eldaman,
great question! I have matte laminated doors at home myself and can say from experience: avoid sharp or alcohol-based cleaners. The laminate reacts quite sensitively to those. It’s best to use a damp microfiber cloth (not soaking wet) with a little mild dish soap. Then gently wipe, don’t scrub.
And hey, try going over it afterwards with a dry microfiber cloth – that way you won’t get any unpleasant water spots or streaks. It might sound like a bit of a care ritual, but it really works! 😊
TEOZAR
3 Apr 2024 11:17
Hello Eldaman,
I can confirm and add to the tips from loken:
1. Always start with a soft, lint-free microfiber cloth.
2. Avoid aggressive cleaning agents such as acetone, alcohol, or abrasive substances.
3. A slightly damp cloth with water or a mild soap-based (pH-neutral) cleaner is ideal.
4. Wipe in circular motions and avoid applying strong pressure.
If you have stubborn stains, you can use a mixture of warm water and a mild all-purpose cleaner, but please use it sparingly. Always dry the surface afterward.
According to Ikea itself, solvents or abrasive cleaners should not be used, which aligns well with these tips.
Marcellela
3 Apr 2024 12:05
I would do it the same way: microfiber cloth, a mild dish detergent, no alcohol, no glass cleaner. It is important not to clean with too much moisture, as it can seep under the film.
kasan
3 Apr 2024 12:47
It is also important to assess the foil properly: not all types of foil are equally durable. Although Ikea does not provide detailed information about the material composition of the Pax doors, forums often mention different reactions with cheaper foils.
I believe plain water cleaning is insufficient, but at the same time, you really need to use appropriate cleaning agents.
Are there any precise test reports or official statements from Ikea regarding cleaning or warranty in case of damage? Otherwise, there is always the risk of permanently damaging the surface due to improper care.
Nabla64
3 Apr 2024 13:32
to organize the process a bit more clearly:
- Preparation: Gently remove the coarse dirt from the door using a dry dust cloth
- Cleaning solution: warm water with mild soap, no solvents or alcohol
- Method: lightly dampen a soft microfiber cloth, clean in circular motions or straight strokes (depending on the type of dirt)
- Follow-up: immediately wipe off with a dry microfiber cloth to avoid water spots
Common mistakes:
- Using harsh sprays and glass cleaners
- Excessive liquid seeping into the edges of the film
- Scrubbing pads or coarse sponges
If these points are observed, the film will remain undamaged for a long time.
