ᐅ Are there any tips for perfectly adjusting Ikea Pax doors?
Created on: 3 Dec 2020 18:07
Sanus
Sanus
3 Dec 2020 18:07
Hello everyone, I am currently installing my Ikea Pax doors but having trouble adjusting them so that they close perfectly and align flush. Sometimes the doors stick or don’t close smoothly. Is there anyone in this forum with experience who can share tips on how to optimally adjust the doors of the Pax wardrobes? I am especially interested in advice on which screws to adjust exactly, whether to start at the top or bottom hinge, and if there are any tricks to compensate for unevenness without removing the doors. I would really appreciate detailed and practical tips.
mifra
3 Dec 2020 18:45
Basically, Pax doors can be adjusted in three ways: vertically, horizontally, and in depth. The adjustment screws are located on the hinges, usually small Phillips screws.
- For vertical adjustment, turn the screw directly on the hinge to raise or lower the door.
- Horizontal adjustment is done using another screw that moves the door closer to or further away from the cabinet.
- Depth is often adjusted by turning the rear screw on the hinge.
It is important to make adjustments gradually and close the door in between to check the effect. If there are uneven gaps, it often helps to adjust each hinge separately. I recommend using a good Phillips screwdriver with a fine tip for precise positioning.
Jeanbar
3 Dec 2020 19:23
I can fully agree with mifra’s instructions. Additionally, it helps to carefully align the cabinet itself before adjusting the doors. Adjustable feet and a spirit level are your best tools here.
I also had issues with sticking doors on my Pax at first. After studying the assembly manual and properly aligning the cabinet frame, I proceeded as follows:
- First, adjust the top hinge to roughly align the door.
- Then fine-tune it using the bottom hinge.
If you have significant unevenness in the floor, you must compensate for that first; otherwise, adjusting the doors will have little effect.
Kukar
4 Dec 2020 07:12
Always make sure the cabinet itself is securely fixed and level. Then adjust the upper hinges so the door doesn’t scrape at the bottom. After that, fine-tune the adjustment at the bottom.
GiRoyce
4 Dec 2020 09:38
To compensate for uneven surfaces, you can also place thin felt pads or cut-to-size PET sheets under the cabinet feet if the cabinet wobbles on one side. After that, adjust the doors, which makes the process much easier.
When adjusting the doors, always work slowly and make small changes, otherwise it becomes difficult to find the optimal setting. From my experience, always document the work done on each hinge carefully, as it is easy to lose track otherwise.
mifra
4 Dec 2020 11:57
Sanus schrieb:
I am especially interested in advice on exactly which screws to adjust and whether to start with the upper or lower hinge
Whether you adjust the upper or lower hinge depends on the issue: If the door is not flush with the frame, the horizontal screw on the upper hinge is usually the right one to start with. For height adjustments, the vertical screws on both hinges are important. To adjust the depth, meaning the distance to the cabinet front, there is a separate screw located at the rear part of the hinge.
A good tip is to first make rough adjustments on one hinge and then fine-tune on the other. This prevents simultaneous adjustments, which can quickly become frustrating.
