ᐅ What is the best way to clean Ikea Pax wardrobes with matte surfaces?
Created on: 8 Jan 2024 08:17
danlau
danlau
8 Jan 2024 08:17
Good morning everyone, I have a question that’s been on my mind for a few weeks and I’m hoping to hear about your experiences: What is the best way to clean Ikea Pax wardrobes with matte surfaces? It’s important to me that the surface isn’t damaged, as matte painted fronts are often more delicate than high-gloss or veneer finishes. Can special cleaning products be used for this, or is a damp cloth sufficient? My main concern is that aggressive cleaners might harm the matte effect or leave unpleasant stains. Who has tips on proper care and cleaning that won’t damage the material over time? I would also appreciate advice on what to avoid. Thanks in advance for your detailed feedback!
SETHBLA
8 Jan 2024 08:45
Hello, I clean my Ikea Pax with a slightly damp microfiber cloth and mild dish soap. No harsh cleaners or abrasive materials. Afterwards, I wipe it dry to preserve the matte finish.
U
usbla
8 Jan 2024 09:12
The matte finish on Ikea Pax is generally quite sensitive to strong chemicals. The following approach has proven effective:
- Avoid alcohol, abrasive cleaners, or solvents
- Gently clean with warm water and a drop of pH-neutral dish soap
- Use a soft microfiber cloth
- Wipe dry immediately after cleaning to prevent water spots
It is also advisable to test any possible stains first on an inconspicuous area.
klo61
8 Jan 2024 09:38
The question is very well asked and shows that you really want to care for the material gently. From my own experience, I can tell you that with matte painted surfaces, special attention should be paid to the following:
- Never use coarse sponges or brushes, as small scratches become quickly visible.
- Harsh cleaning agents are usually not tolerated; a mild dish soap and water mixture or special cleaners for delicate surfaces are sufficient.
- For stubborn stains, you can carefully use a paste made of pure soap or baking soda, but always test it first.
If you like, I can also provide you with a step-by-step guide.
danlau
8 Jan 2024 10:15
usbla schrieb:
It is also advisable to test possible stains first on an inconspicuous area.
Thank you, that’s a very good tip! How long would you usually leave such a test to take effect? 10 minutes, an hour?
Also, a question about microfiber cloths: I have different types at home. Are there differences in terms of material density or fiber type? And what should I specifically look out for to avoid damaging the surface?
SETHBLA
8 Jan 2024 10:42
10-15 minutes is usually enough, then you can carefully wipe it off with a damp cloth and check if the surface has been affected.
Regarding the cloths: Always use pure, soft microfiber cloths without any coarse texture or integrated scrubbers.
