ᐅ Are there color options available for customizing Ikea PAX wardrobes?
Created on: 7 Nov 2024 08:37
Lobenno
Lobenno
7 Nov 2024 08:37
I am currently working on designing Ikea PAX systems and would like to know if there are ways to customize or expand the surface finish and color options of the PAX wardrobes. Specifically, I am interested in whether it is possible to paint, apply vinyl wraps, or otherwise change the color of the doors or carcass panels on your own, without compromising stability or voiding the warranty.
Are there any special products suitable for this? Or does Ikea offer options for alternative colors beyond the standard range?
I look forward to your experiences and tips regarding the question: "Are there any color options for customizing Ikea PAX?"
Jensson
7 Nov 2024 09:12
Hello Lobenno,
here are some insights and tips regarding color customization for Ikea PAX from my side.
Basically, there are several ways to adjust the color of your PAX:
- Ikea offers a limited selection of door front colors (white, black-brown, birch, gray, etc.) that you can choose when purchasing.
- For more individual color variations, you can:
- Sand the fronts and then repaint them with special furniture paint (acrylic or 2K coatings take time but are durable).
- Use adhesive films or self-adhesive vinyl wraps – these come in various colors and patterns, are easy to apply, but may not always be perfectly durable.
- There are plastic and wooden fronts, whose materials vary in how well they accept paint.
Important: Before painting, make sure to clean the surface thoroughly, possibly sand it lightly, and use the appropriate primer to ensure the paint adheres properly.
Regarding whether the warranty is voided by painting – usually not, as long as no essential parts are damaged. However, Ikea generally does not recommend DIY modifications, so proceed at your own risk.
Summary:
- Standard color options are limited
- Repainting and wrapping possible
- Preparation with sanding and priming necessary
- Warranty may be affected if damage occurs due to modifications
If you want to go deeper into the topic, I can gladly provide more details about paint types and preparation.
koduga
7 Nov 2024 11:04
I just want to say that I find your question really important because I’m currently considering giving my PAX wardrobes a more personal touch.
When you invest in a piece of furniture for a longer time, you don’t want to stick with the standard colors—you want something that truly fits the room and your personality.
I have tried using adhesive vinyl, but it wasn’t easy for me—it requires patience and a steady hand; otherwise, the seams look quite messy. Sometimes, though, I enjoy starting projects like this.
So, I would definitely recommend experimenting a bit and paying attention to the quality of the vinyl or paint, so the result lasts and looks good.
Sometimes, you quickly realize you need help. So: Does anyone know other options or have experience with special paints or techniques?
Filippo
7 Nov 2024 13:46
The topic of color options for Ikea PAX is quite extensive, so I would like to provide a more detailed answer—especially regarding technical aspects and process details.
First of all, it is important to differentiate between the carcass and the fronts. The carcass is usually made of melamine-coated particleboard, which is not ideal for painting due to its surface, as paint often adheres poorly and can cause bubbling or chipping.
The fronts come in different versions (wood veneer, MDF with paint, high gloss with foil), and here an individual assessment is worthwhile:
- MDF fronts with paint are best suited for further refinishing because they offer a smooth surface that can be sanded and primed well.
- Foil-coated fronts, on the other hand, must be carefully sanded to roughen the foil to ensure that the new paint adheres.
Regarding the technique, I recommend a multi-step approach:
1. Remove fronts and hardware
2. Gentle cleaning
3. Sanding with fine sandpaper (grit 220–320)
4. Priming with a suitable primer (acrylic- or synthetic resin-based, adapted to the material)
5. Sanding between coats
6. Several layers of paint (acrylic or two-component), to achieve a durable finish
7. After drying, possibly sealing with clear coat
The working environment is also important: dust-free, well ventilated, and with temperature control.
Foiling is a less labor-intensive alternative but is not as durable or resistant—here, high-quality foils with UV and scratch protection should be used.
Finally, a brief question for Lobenno: How much time and carpentry skill are you willing to invest in the project? Do you already have a specific color idea or technique in mind?
Lobenno
7 Nov 2024 14:59
Filippo schrieb:
How much time and DIY experience are you planning to invest in the project? And do you already have a specific color idea or technique in mind?
Thank you for the detailed response, Filippo!
I would say I have some basic knowledge and practical skills, but not professional painting experience. That’s why I prefer not to choose very complex painting methods at first, as I want to see how the cabinet fits in the room before attempting a professional finish.
My color preference leans toward a matte, muted blue or gray that complements modern interior designs.
For now, I am particularly interested in whether, for example, vinyl wraps or spray paint (bought directly from a hardware store) can deliver a reasonably acceptable quality, or if it’s better to avoid them altogether.
lisku
7 Nov 2024 16:22
Foils are a simple solution for new colors, especially if you don’t want to make major changes to your PAX.
For spray paint from a hardware store, you should sand thoroughly beforehand and use a primer; otherwise, the paint often doesn’t adhere well.
I would recommend testing on a small, less visible area first.
