ᐅ What is the best way to clean Ikea PAX glass doors?
Created on: 3 Feb 2022 10:12
Totovin
Totovin
3 Feb 2022 10:12
Hello everyone, I have a rather specific question regarding the cleaning of my Ikea Pax wardrobe doors with glass fronts. Since these fronts are made of glass, I want to avoid streaks, scratches, or residue from cleaning products. I am especially interested in which cleaning methods and products have proven effective for removing stubborn fingerprints and dust while keeping the glass gently cleaned and permanently clear. Could you share practical tips on whether special glass cleaners are recommended or if simple household remedies work better? It would also be helpful to hear about your experiences cleaning the surrounding frames, which are usually made of plastic or wood. Thanks in advance for your expertise!
liRaul49
3 Feb 2022 10:25
I always use microfiber cloths and a little water with mild dish soap. I wipe the glass with that, then polish it dry with a clean microfiber cloth. Do not use any aggressive cleaning agents.
BOSULE
3 Feb 2022 11:03
To clean IKEA PAX glass fronts, I recommend using a chemical-free, alcohol-free glass cleaner or a homemade vinegar-water solution (50:50) to avoid streaks. Microfiber cloths are ideal, as they do not cause scratches. For the frames, use a mild cleaner suitable for the material—special wood care products for wood, or a basic all-purpose cleaner for plastic. It is also important not to use too much liquid to prevent water spots.
Matthewt48
3 Feb 2022 12:15
Hello Totovin, I’m quite familiar with this issue because glass fronts are sensitive to streaks and scratches. Generally, the following sequence works well: - Wipe off coarse dust with a dry microfiber cloth - Use a slightly damp cloth with a mild glass cleaner (preferably ammonia-free) - Follow up by wiping with a dry, soft cloth For stubborn fingerprints, small amounts of rubbing alcohol in water can also help. You especially need to be careful with the frames, as you mentioned: for wood, the cleaning agent should not be too aggressive or too wet, to avoid swelling. Plastic frames can usually handle a bit more moisture, but harsh chemicals may cause dulling. Important: Do not use abrasive cleaners or rough sponges that could scratch the glass. I hope this helps you for now. If you like, I can provide more details on specific products and procedures.
Benge5
3 Feb 2022 13:44
I would like to point out that cleaning glass fronts on furniture such as Ikea PAX is not only for cosmetic reasons but can also affect the durability of the material. Based on my research, it is advisable to use only pH-neutral cleaning agents to avoid damaging the glass. Additionally, always use a soft microfiber cloth or a lint-free cotton cloth to prevent scratches. In particular, when using a vinegar-water solution, it should be noted that while it is effective against limescale and dirt, a concentration that is too high can cause damage to the seals of the frame. Regular cleaning with mild agents and thorough drying is recommended. The chamois leather method for the final cleaning step ensures a streak-free shine.
lajudo
3 Feb 2022 14:07
I clean glass fronts with clear water and a special glass cloth. If necessary, a small amount of dish soap can be used, but sparingly. Afterwards, I immediately wipe them dry with a dry cloth. I clean the frames separately using a mild cleaner.
