ᐅ Which Ikea Pax models are suitable for sloped ceilings?
Created on: 31 Jan 2017 08:37
Luneleo
Luneleo
31 Jan 2017 08:37
Hello everyone, I have an apartment with sloped ceilings and I am planning to make the best use of the available space for my wardrobe. I am interested in the different Ikea Pax models and their suitability for rooms with sloped ceilings. My specific question is: which Ikea Pax wardrobe models or systems are particularly well suited for use in rooms with sloped ceilings? Are there models that adapt better to slanted walls, or special sizes and combinations you would recommend? Any tips on possible modifications or alternatives within the Pax range would also be very helpful. Thanks for sharing your experiences!
kaju67
31 Jan 2017 09:45
Luneleo schrieb:
Which Ikea Pax wardrobe models or systems are particularly well suited for use in rooms with sloped ceilings?
Hey, great question – sloped ceilings are always a bit of a challenge! In general, the classic Pax frames with variable heights are a good starting point. The shorter 201 cm (79 inches) or 236 cm (93 inches) frames are especially popular for angled rooms because they often fit better under the slope.
When the slope is really steep, you can also use open shelves or sliding doors without a top panel instead of tall doors. Unfortunately, Ikea doesn’t offer a special sloped Pax, but with a bit of DIY and careful planning, you can definitely create something cool. Tip: sometimes the sliding door track systems can be adjusted to fit under sloped ceilings—not always perfectly clean, but it’s possible.
The combination of lower frames and adjustable shelves that you can position yourself makes the difference. If you enjoy DIY, you can also trim the back panels to match the slope. Good luck with your project!
SINEL
31 Jan 2017 10:12
For sloped ceilings, I recommend the Pax versions with a height of 201 cm (79 inches) or 236 cm (93 inches). These are lower and fit better under angled ceilings than the 236 cm (93 inches) tall models. Additionally, sliding doors can be chosen instead of hinged doors to save space.
Marsar
31 Jan 2017 11:05
I would like to add that it is important to measure the slope precisely and then plan what width and height are possible. Ikea often uses a 50 cm (20 inch) width grid – this limits flexibility somewhat, although the Pax system offers different widths (50, 75, 100 cm / 20, 30, 40 inches).
For sloped ceilings, the lower frames with a height of 201 cm (79 inches) are particularly suitable because they can often be adapted to the slope. The doors may need to be adjusted at the top or omitted entirely if the slope is too steep.
I would also recommend taking measurements and possibly using frames without doors, combined with rolling containers or open shelving units; this way, you can work flexibly under the slope. In general, many advise leaving out the upper parts and using the lower-height space intelligently.
If possible: The Pax construction must be securely screwed to the wall, especially with sloped ceilings, to provide additional stability.
kla65
31 Jan 2017 11:47
Pax 201 cm (79 inches) frames are the best choice for sloped ceilings. A width of 50 cm (20 inches) is the most flexible. It is best without upper cabinets; instead, use shelves that can be adjusted individually. Doors can be cut to size or omitted.
dinano
1 Feb 2017 08:12
Marsar schrieb:
I would like to add that it is important to measure the slope precisely and then plan which width and height are possible.
That is exactly the key point: many assume that you can simply use standardized Pax modules and manage with them. That is not quite true. The grid dimensions are very rigid specifications that cannot be easily adapted to an individual slope.
That may be true, but only if the slope is not too steep. When it becomes steeper, it is worth considering custom-made solutions or special corner designs. Additionally, the stability of the Pax construction with individually cut parts is not always guaranteed; anyone making adjustments should thoroughly check the attachment methods.
I would also question whether a Pax system with its fixed grid division really offers the best storage space under sloped ceilings. Sometimes flexible shelving systems or even compact built-in wardrobes are the better alternative.
