ᐅ How can Ikea Pax doors be customized with stickers or painted?
Created on: 24 Mar 2021 09:17
chenli52
chenli52
24 Mar 2021 09:17
Good morning everyone, I am planning to customize my Ikea Pax wardrobe doors to better match my home interior. I am especially interested in the options for either professionally applying or doing it myself as an enthusiastic DIYer, whether by using adhesive films or paint.
I would appreciate advice on suitable materials, preparation steps (e.g., sanding, priming), the durability of different methods, and tips for achieving a smooth and long-lasting finish. Are there specific films or paints that adhere particularly well to the door material? What special considerations should be taken into account when working with the most commonly used front materials (particleboard with melamine coating)?
I look forward to your practical experiences and recommendations.
sihau
24 Mar 2021 09:53
Hello chenli52,
I will summarize and add some information: Ikea Pax doors are usually made of particleboard with a melamine or foil coating. These surfaces are smooth and often difficult to cover because they offer little adhesion.
For applying coverings, high-quality self-adhesive films or vinyl wraps designed for furniture work well. Before application, it is important to thoroughly clean the surface and lightly sand it (e.g., with fine 400-grit sandpaper) to improve adhesion.
If painting, you must use a primer suitable for smooth surfaces. Acrylic or acrylic-based paints are suitable for the final coat, which can be applied with a roller or spray. Multiple thin layers are better than a few thick ones. A clear coat finish increases durability.
Note: The edges of the doors are particularly sensitive and must be handled carefully to prevent chipping or peeling.
Summary:
- Clean the surface
- Lightly sand
- For covering: use high-quality, well-adhering films
- For painting: primer + thin layers of paint + clear coat
- Pay special attention to the edges
With careful work, the result holds up very well and looks professional.
Daledra
24 Mar 2021 10:06
For bonding: Smooth the film with a squeegee to avoid air bubbles.
When painting: Spray paint provides more even layers than a roller.
Be sure to sand thoroughly and remove dust beforehand.
enrique7
24 Mar 2021 10:27
sihau schrieb:
High-quality, self-adhesive films or vinyl films designed for furniture are suitable for applying.
That may generally be true, but it is important to differentiate: Not every adhesive used on furniture films is suitable for long-term use on melamine surfaces. Especially lower-cost films often show adhesion problems after a short time.
It would be helpful to provide specific manufacturers or product recommendations that are specifically designed for melamine coatings – otherwise, there is a risk that the film will peel off after a few months.
Also, how do the doors look and feel after applying the film? Are the edges clearly visible, or does the color really match well? The 3D surface texture of some films can appear distracting on smooth doors like Pax.
naujon
24 Mar 2021 11:13
In addition to the previous posts, here are some practical tips for painting Pax doors:
1. Preparation: Remove all hardware and handles before sanding to ensure a uniform surface.
2. Sanding: Use 220-grit sandpaper to gently roughen the surface. Caution: sanding too aggressively can damage the melamine coating.
3. Cleaning: Degrease the surface with a lint-free cloth and, if needed, isopropyl alcohol.
4. Primer: Apply a special adhesion primer designed for smooth surfaces to ensure paint adhesion.
5. Paint: Water-based acrylic paint is recommended due to its low odor and environmental friendliness.
6. Application: Use a high-quality foam roller and apply thin coats, allowing each layer to dry thoroughly.
7. Edges: Pay extra attention to edges and corners—small brushes can be useful here.
8. Sealing: Clear coat or protective lacquer ensures a durable finish.
Tip: Patience is key to a good result, so allow sufficient drying time between each step.
elliot
24 Mar 2021 12:02
The melamine layer is hard and scratch-resistant but also very smooth, which makes adhesion difficult.
Therefore:
- Avoid aggressive cleaners and abrasive sanding materials.
- Sand only lightly to roughen the surface, not to expose the underlying material.
- Use a primer that adheres well to melamine (e.g., multi-purpose primer, adhesion primer).
chenli52 schrieb:
Are there specific films or paints that adhere particularly well to the material used for the doors?
For films, I recommend using high-quality furniture film with a polyacrylate adhesive, as it adheres flexibly and durably.
Paints should be suitable for plastics/melamine—such as two-component acrylic or polyurethane paints.
Important: Pay special attention to professionally treating the edges, as they tend to fray easily or the paint may chip.
