ᐅ Which Ikea PAX doors are the most durable?
Created on: 31 May 2023 09:23
U
USPAU58
U
USPAU58
31 May 2023 09:23
I am planning to expand my Ikea PAX wardrobe system in the coming weeks and am currently selecting the appropriate doors. It is particularly important to me that the doors not only look good but are also as durable as possible, since the wardrobes are used daily.
My specific question is: Based on your experience or known materials and construction methods, which Ikea PAX doors are especially durable? I am referring to factors such as scratch resistance, hardware stability, and overall robustness in everyday use.
Do you have recommendations on which door models perform better in these respects, perhaps compared to others, or tips on what to pay particular attention to when choosing?
I look forward to clear and well-founded responses!
Kukar
31 May 2023 09:45
The PAX doors with MDF solid wood fronts are sturdy and scratch-resistant. The "VOXTORP" series, in particular, is very durable. Metal fittings should be properly adjusted and maintained.
Paxton38
31 May 2023 10:17
Regarding the durability of PAX doors:
- Doors made from solid MDF panels with a melamine coating show higher scratch and impact resistance compared to doors with foil surfaces.
- Glass fronts require more maintenance but can be equipped with safety glass, which improves stability.
- Fronts with frame and panel construction, such as the "TYSSEDAL," often offer better resistance to warping.
The door hardware system is also important: soft-closing hinges extend the lifespan of the doors by cushioning impacts.
Overall, I find the "VOXTORP" and "TYSSEDAL" series to be particularly durable, depending on the application.
BARSAN
31 May 2023 11:02
I installed doors from the "VOXTORP" series in my home and can say that the surface is very durable. Especially in the kitchen, it withstands moisture and scratches well.
Cecilera66
31 May 2023 11:35
If surface scratches are especially important to you, I would recommend doors with a melamine coating. They are durable and easy to clean, which positively affects their lifespan.
nubar
31 May 2023 12:14
In addition to the previous information: For the durability of PAX doors, not only the choice of the front but also the correct installation of hinges and fittings plays a crucial role. Even the highest quality door can show damage sooner if installed improperly.
I also recommend reviewing Ikea’s care instructions to preserve fittings and surfaces over the long term.
