ᐅ Which Ikea PAX doors are the most durable?
Created on: 31 May 2023 09:23
U
USPAU58
I am planning to expand my Ikea PAX wardrobe system in the coming weeks and am currently selecting the appropriate doors. It is particularly important to me that the doors not only look good but are also as durable as possible, since the wardrobes are used daily.
My specific question is: Based on your experience or known materials and construction methods, which Ikea PAX doors are especially durable? I am referring to factors such as scratch resistance, hardware stability, and overall robustness in everyday use.
Do you have recommendations on which door models perform better in these respects, perhaps compared to others, or tips on what to pay particular attention to when choosing?
I look forward to clear and well-founded responses!
theo63
31 May 2023 13:02
I find it interesting how often the term "durable" is used without clearly defining what is meant.
Does durability here refer only to scratch resistance? Or does it also include the mechanical strength of the fittings and the dimensional stability of the door under changing humidity conditions? The “RAMSJO” doors, for example, have a traditional frame construction that better resists warping compared to full-surface panels.
Have people already had experience with whether solid wood or MDF high-pressure laminate panels are actually more durable? I’m not saying that the more expensive options are automatically better, but this should be considered in a nuanced way.
Paxton38
31 May 2023 13:40
theo63 schrieb:
I find it interesting how often 'durability' is mentioned without clearly defining what is meant.
Exactly. Durability should be seen as an overall concept: materials, surface finish, fittings, and also the usage scenario. For heavily used doors, a combination of melamine-coated MDF fronts and soft-close hinges is recommended.
theo63 schrieb:
Has anyone had experience whether solid wood or high-pressure MDF boards actually last longer?
MDF is primarily attributed with higher dimensional stability, while solid wood tends to warp more with fluctuating humidity. The surface seal then determines scratch resistance and maintenance.
KNUTGI
31 May 2023 14:18
Durability applies not only to the material but also to the appearance, which you want to maintain for as long as possible. I chose the matte "VOXTORP" finish for my kitchen. Even after 3 years, it still looks like new despite daily use.
Additionally, the soft-close hinges are fantastic—no more slamming, and they definitely last longer!
KAUDRA62
31 May 2023 15:05
Just wanted to point out that matte-coated doors like "VOXTORP" not only resist scratches better but also show fewer fingerprints. This significantly helps maintain their appearance over time.
Even if you’re loading things in roughly or neighbors accidentally bump into the door – it really holds up well.
U
USPAU58
1 Jun 2023 08:47
Thank you for the responses so far; they have been very helpful.
Paxton38 schrieb:
An important factor is the door hardware system: Soft-closing hinges extend the lifespan of doors by cushioning impacts.
How about maintenance for these? Do soft-close mechanisms need regular adjustment or lubrication to maintain their durability, or are they generally considered maintenance-free?
Also, are there significant differences in the load capacity of hinges, or how much weight a door can support at maximum?
I would appreciate it if anyone has experience or technical details on this.
nubar
1 Jun 2023 09:31
USPAU58 schrieb:
What about maintenance? Do these soft-close mechanisms need regular adjustment or lubrication to ensure durability? Or are they considered maintenance-free?
Soft-close hinges from Ikea are generally low-maintenance. Occasional light cleaning and possibly a drop of silicone oil or grease can be helpful, but it is not strictly necessary.
USPAU58 schrieb:
Are there significant differences in the load capacity of the hinges, or how much weight a door can support at most?
The load capacity is usually specified in the product description. Generally, the standard hinges are designed for doors weighing up to approximately 15 kg (33 lbs). For heavier doors such as glass or solid wood fronts, Ikea recommends specific fittings.
Be careful with excessive loads: the lifespan of the hinges decreases significantly.
