ᐅ Easily Retrofit and Adjust Soft-Close Doors for Ikea Metod Cabinets
Created on: 11 Jul 2019 08:37
SAN59Hello everyone, I recently installed my kitchen using the Ikea Metod system and would like to retrofit the already mounted doors with a soft-close function. My goal is to add this feature as easily and quickly as possible and then adjust it optimally so that the doors close smoothly and quietly. I am particularly interested in which exact parts are needed, whether any special tools are required, and how to best adjust soft-close doors on the Metod system. Perhaps someone here has experience with this and can explain the process step by step—ideally with tips on what to pay special attention to, so the retrofit really works without any issues. Thanks in advance!
SAN59 schrieb:
My goal is to retrofit the doors easily and with minimal effort, and then adjust them perfectly so they close smoothly and quietly.Hey, that sounds like a great plan for your kitchen! Soft-close for Ikea Metod cabinets is really a fantastic feature, and retrofitting it is not as complicated as it seems. You mainly need the soft-close dampers, which Ikea calls the “soft closing mechanism” or something similar. Tools? Just a Phillips screwdriver and a bit of patience – the rest pretty much takes care of itself.
When adjusting, the key is to position the damper correctly on the door. Once the door is hung, you can make small adjustments to the hinges to ensure the closing action is smooth and quiet. And don’t worry, just gently push the doors closed – the soft-close dampers will handle the rest! Good luck, and let us know how it goes!
As additional information: If you want to retrofit the soft-close function, you should know that the Metod hinges usually already have the option for dampers. If your hinges do not have a soft-close mechanism, you can often simply replace them with Ikea soft-close hinges, which are specifically designed to fit Metod.
Important points to keep in mind:
- The new hinges fit on the same mounting plate, which makes replacement easier.
- You don’t need to drill new holes; the attachment points remain the same.
- The hinges have screws that allow you to adjust height, depth, and lateral alignment.
Soft-close dampers usually have a spring or hydraulic function that gently cushions the final closing motion. Patience and a steady hand are essential for proper adjustment. If you need more detailed instructions, I’d be happy to provide step-by-step guidance.
I know that switching to soft-close can feel a bit overwhelming at first because you might think you have to take everything completely apart. But that’s not the case.
That was my experience too – just replacing the old hinges and the doors close much more gently. At first, I wasn’t sure if I could do it myself, but step by step it worked out great. I think it’s important to take your time and not try to do too much at once. For me, it also helped to align the doors very carefully before installing the soft-close hinges, to reduce the need for adjustments later.
The result is a big improvement in quality of life because the doors no longer slam, but close gently almost by themselves.
dunitan schrieb:
If your hinges don’t have a soft-close mechanism, you can often simply replace them with soft-close hinges from Ikea, which fit Metod cabinets perfectly.
To streamline the process:
1. Check if your current Metod hinges are compatible with soft-close dampers. Metod usually uses standard fittings, so switching is generally straightforward.
2. If you need to buy new soft-close hinges: these are available as complete units (e.g., Metod soft-close damper hinge).
3. To remove the old hinges, simply loosen the mounting screws.
4. Install the new hinges, paying close attention to precise alignment – small adjustment screws allow fine tuning in three dimensions.
5. If present, adjust the damper mechanism accordingly. Ikea typically does not require any tools for fine-tuning since the system is pre-configured.
The soft-close function prevents doors from slamming shut through hydraulic damping. This extends the furniture’s lifespan and increases comfort. If the adjustment is not perfect at first, minor hinge readjustments usually solve the issue in practice.
I recommend using the Ikea instructions for Metod soft-close hinges alongside this guide, as they provide exact dimensions and adjustment tips.
