Hello everyone, I am planning to upgrade my IKEA Besta furniture with higher-quality hinges because the original ones seem a bit stiff and not very durable. My question is: Which hinges are suitable as an upgrade for the Besta series, considering compatibility, easy installation, and improved functionality? Are there any recommended brands or models that fit the existing drill holes, are not too difficult to install, and offer better durability or smoother opening and closing? I would appreciate details on mounting types, material quality, and any necessary modifications. Thank you in advance for your expertise!
Here is a brief guide on what to consider when upgrading hinges for IKEA Besta:
- Hole pattern: Most hinges have a 35 mm (1.4 inch) cup hole, so be sure to measure before purchasing
- Installation dimensions: Door thickness of 16 mm (0.63 inch) is crucial here; most standard overlay hinges fit this thickness
- Features: Soft-close is recommended to prevent slamming and protect the furniture
- Installation: Plug-and-play hinges simplify installation; make sure to use compatible mounting plates
- Brands: Blum Clip Top, Häfele, and Hettich Sensys are reliable manufacturers
Also, keep an eye on door swing and opening angle, as these significantly affect your choice. If you make adjustments, carefully monitor the drilled holes and material thickness to ensure stability and appearance.
parpeo schrieb:
As an upgrade, higher-quality Blum hinges (e.g., Blum Clip Top) are highly recommended because they are extremely durable, a bit more expensive, but work very precisely.I can confirm that. Blum Clip Top hinges offer very high manufacturing quality and are perfect for most IKEA BESTA doors. Their modular design allows for very precise adjustments, which is especially beneficial for IKEA furniture that typically uses thinner veneer or particleboard panels.
Thank you for the many helpful responses! In summary, I plan to try the Blum Clip Top Soft-Close hinges, as they seem to fit best and are of high quality. I will carefully measure the door thickness and check the drill holes beforehand. If anyone has a tip on the best source to purchase these hinges in small quantities, please let me know. I will update once I start the installation!
