ᐅ How reliable is the load-bearing capacity of Ikea Hemnes furniture in practice?
Created on: 14 May 2022 08:37
Pufaleo
I would like to start a discussion on the topic: How reliable is the load-bearing capacity of Ikea Hemnes furniture really?
I have read in various forums that while the furniture is visually appealing and quite popular, there are recurring reports of stability issues, especially with the drawers and cabinets in this series. I am particularly interested if anyone has solid experience with how much weight can be stored on the individual pieces without compromising their stability.
I am also curious about how durable the build quality is under everyday conditions – for example, how often screws need to be tightened or if wooden slats tend to crack.
Does anyone here have reliable experience or possibly comparison data with similar furniture from Ikea or other manufacturers? The more specific the information, the better! Thank you!
Thank you in advance for your feedback.
I am particularly interested in whether anyone has tested long-term stress from heavier objects. Many pieces of furniture are rated for up to 20-30 kg (44-66 lbs), but what happens if you regularly store 40-50 kg (88-110 lbs) on shelves, for example? Is there a significant risk of warping or damage? This is especially important for the Hemnes series, which often includes open shelves or display cabinets.
Additionally, I would like to know about the durability of the fittings (hinges, drawer dampers, etc.) with continuous use. I have heard differing opinions and would appreciate it if someone could share concrete experiences on this.
Regarding load capacity beyond the specified values: Hemnes furniture is not designed to support a permanent load of 40-50 kg (88-110 lbs) per shelf. The materials and construction are intended to carry typical household items, not industrial weights.
As for the fittings, their quality is average. The hinges are sturdy enough for everyday use; however, wear becomes noticeable after several years of frequent use.
The simplicity of the design at Ikea offers the advantage of easily replaceable individual parts. It is recommended to regularly check and tighten the screws.
One more provocative thesis: Perhaps consumers themselves share some responsibility for the decline in furniture quality by expecting a single piece of furniture to meet all demands – from design to industrial-level durability.
Ikea clearly communicates the load capacity, and anyone who ignores this risks damage, which in turn leads to negative reviews. These specifications simply should not be overlooked.
Gregory schrieb:
Regarding load capacity beyond the specified values: Hemnes furniture is not designed to permanently support 40-50 kg (88-110 lbs) per shelf.
That’s a good point. I’m asking in such detail because I’m considering using a Hemnes desk for my home office, which will often be loaded with heavy equipment and multiple monitors.
My concern is that although the furniture looks nice, it might wear out prematurely or become unstable over time due to the load.
Therefore, I’d like to ask: Are there any concrete experiences with Hemnes furniture used in office or home office settings? Specifically regarding load capacity, stability, and the durability of mechanisms (desk drawers, etc.).
I also use Hemnes in my home office, mainly as a shelf and sideboard. The load from electronic equipment is limited, but I notice that regular tightening is necessary. For me, it’s a compromise between appearance and durability – not perfect, but acceptable for the price.
If you expect heavy, long-term use, an alternative made of solid wood with more robust metal fittings might be better.
AUSTINREN15 May 2022 13:39Summary and Recommendation:
- Ikea Hemnes furniture is mostly made of solid wood and offers reliable load capacity within the specified limits (typically 20-30 kg [44-66 lbs] per shelf).
- Caution is advised for higher loads (over 30 kg [66 lbs]), as material fatigue and deformation may occur.
- For use in home offices and with electronic equipment, it is recommended to reinforce the furniture or use pieces specifically designed for this purpose.
- Screws should be checked regularly and tightened if necessary, which is common practice for all furniture with fasteners.
- The quality of the fittings is sufficient for private home use; however, signs of wear may develop with frequent heavy use.
Overall, Hemnes is a good choice for budget-conscious customers who do not consistently place extremely heavy loads on the furniture.
