ᐅ Which hinges are suitable as replacements for Ikea Besta?
Created on: 7 Oct 2020 09:13
kloni
Hello everyone, I have a Besta shelving unit from Ikea, but unfortunately the original hinges are damaged. I’m now looking for suitable replacement hinges that can be used as alternatives. It’s important that the hinges fit without major modifications and use the same mounting points. I have done some research but found a lot of conflicting information about what is actually compatible. So my specific question is: Which hinges work as replacements for Ikea Besta? Are there any recommendations regarding manufacturers, dimensions, and installation, or perhaps tips on what to consider when replacing them? Thanks for your support!
Keatondra
7 Oct 2020 12:01
Hello kloni, it’s great that you’re asking such a specific question! For Ikea Besta, 35mm cup hinges with soft-close function generally fit very well. The best options are brands like Blum or Hettich, which are often universally suitable.
It’s important to check three things: door thickness, cup hole depth for the hinge (usually 12–14 mm (0.5–0.6 inches)), and the spacing of the mounting holes. Once you have these measurements, you can choose much more precisely when shopping.
If you don’t have much experience with hinges yet, I recommend studying the hinges and installation instructions carefully. This will help you avoid mistakes during installation. If you have any more questions, I’m happy to assist!
Torsten45
7 Oct 2020 12:19
Summary of my research: Ikea Besta typically uses 35 mm (1⅜ inch) concealed hinges with integrated soft-closing and an opening angle of approximately 110 degrees.
- Installation follows standard drilling patterns commonly used by hinge manufacturers such as Blum or Hettich.
- Door thickness is usually between 16 and 18 mm (⅝ and ¾ inch).
- Minor deviations may occur but can be compensated with adjustable hinges.
As replacements, I recommend:
- Blum Clip Top BLUMOTION
- Hettich Sensys
Both manufacturers also offer soft-close systems that enhance convenience. Installation only requires a properly sized drill hole (35 mm / 1⅜ inch) in the door panel, with a drilling depth of about 5 mm (⅕ inch). The cabinet screws are mostly standardized.
This way, you can replace Ikea hinges with minimal issues.
kloni
7 Oct 2020 13:47
PLOMA schrieb:
Could you specify the hinge type more precisely (e.g., with or without damping, opening angle), and roughly how old your cabinet is? Also, whether the door material is thicker, thinner, or painted can be crucial for the choice.
Thank you, PLOMA, for the detailed response! Here is my current situation: It is a Besta cabinet, about 4 years old, with white doors made from a 16 mm (5/8 inch) MDF panel, painted. The hinges had a damping function since they were soft-close. The opening angle was 110 degrees (approximately), as far as I can tell.
I will remove the door again and check the measurements carefully, but this seems to match the standard you described quite closely.
I basically want a direct 1:1 replacement, no modifications to the doors or the cabinet, as I do not want to adjust the unit. Original parts from Ikea are unfortunately no longer available or are hard to obtain. Are there really third-party replacement parts that fit exactly without adjustments? Or will I have to accept compromises when buying from other suppliers?
PLOMA
7 Oct 2020 14:12
kloni schrieb:
Are there really third-party replacement parts that fit perfectly without any modifications? Or do I have to compromise when buying from other suppliers?
That’s the key question! In principle, there are some third-party hinges that come very close to the Ikea standard, but 100% accurate fits are often only found with originals or hinges from top brands designed specifically for the 35mm (1 3/8 inch) cup, 16mm (5/8 inch) door thickness, and common drilling patterns.
Most Blum Clip Top hinges with a 110° opening angle and BLUMOTION soft-close usually fit without problems—they are essentially the industry standard for furniture with concealed mounting.
You just need to be cautious with hinges that have different attachment methods (e.g., screw fasteners versus clip-on) or different hole spacing.
My advice: If you don’t insist on originals, it’s better to buy a pair of high-quality Blum hinges. They can be adjusted to fit and generally offer the same functionality as the original. Even if you need to drill minimal new holes in the carcass, these hinges hold very well on MDF.
What is your stock of old hinges? Are the metal mounting plates on the carcass still present, or do you plan to replace those as well?
U
usron
7 Oct 2020 15:07
kloni schrieb:
Original parts directly from Ikea are unfortunately no longer available or are hard to get.
That’s really unfortunate, but sometimes it happens. In such cases, I simply contacted Ikea customer service, and they were able to find something from their leftover stock, so it might be worth a try.
Otherwise, I did it with a friend who had similar hinges from Blum left over and adapted them for me. It works! Just give it a try 🙂
Wesley
7 Oct 2020 15:41
Kloni,
I really like the Blum hinges; they fit perfectly as a replacement. They can be a bit more expensive sometimes, but if you want to avoid the hassle of fiddling and adjustments, they are exactly the right choice.
And don’t worry about the drill holes—these hinges usually have small adjustment screws that allow you to set everything with millimeter precision.
If you also oil the doors a little or apply some wax with a brush, everything will close smoothly. Good luck!
