Hello everyone, I have a Besta shelving unit from Ikea, but unfortunately the original hinges are damaged. I’m now looking for suitable replacement hinges that can be used as alternatives. It’s important that the hinges fit without major modifications and use the same mounting points. I have done some research but found a lot of conflicting information about what is actually compatible. So my specific question is: Which hinges work as replacements for Ikea Besta? Are there any recommendations regarding manufacturers, dimensions, and installation, or perhaps tips on what to consider when replacing them? Thanks for your support!
In my experience, replacing Besta hinges is not just a technical task but can also be quite frustrating if you’re not careful.
What you definitely want to avoid are gaps caused by hinges that don’t fit properly. My advice is to always test the hinge thoroughly before installation and, if possible, do a trial mount on an old door or a piece of wood.
If you do need to drill new holes, make sure to carefully fill the old ones first so the new screws will hold properly, and don’t forget to treat the surface afterwards.
The hinges come with mounting plates included in case the distance from the cabinet body varies. These are standard items with brands like Blum or Hettich. This makes the conversion much easier.
Torsten458 Oct 2020 09:44One more precise note from me regarding replacements:
Besta hinges are concealed cup hinges with a standard cup diameter of 35 mm (1.38 inches) and a drilling depth on the door leaf of about 12-13 mm (0.47-0.51 inches), which is usually standardized among most high-quality hinge manufacturers.
The following points are important:
- Make sure the replacement hinge has soft-close damping, according to your description.
- Choose a version with a clip-on mechanism to allow easy installation and removal.
- Check whether the screw holes on the cabinet body match the existing mounting plates; if necessary, these can be replaced.
Conclusion: Blum Clip Top BLUMOTION and Hettich Sensys 110-degree hinges are the best replacements. These are almost exact fits and have universal mounting.
