ᐅ How do I adjust IKEA BESTA doors so they close perfectly and evenly?
Created on: 4 Apr 2023 10:07
Finnsi
Finnsi
4 Apr 2023 10:07
Hello everyone, I have an issue with my IKEA Besta doors. The doors don’t close perfectly and appear uneven – in some places there is a gap, while in others they press too tightly. I know the doors can be adjusted, but I find the manual a bit confusing.
Could someone please explain in detail the exact steps needed to adjust the doors so they close completely evenly and cleanly? I would like to know which screws to turn, in which directions, and if there are any special points to keep in mind to ensure the doors neither stick nor sit too loosely.
SETHBLA
4 Apr 2023 10:23
The IKEA BESTA doors usually come with adjustable hinges.
- Screw 1 adjusts the height.
- Screw 2 adjusts the depth, meaning how far the door extends outward.
- Screw 3 adjusts the lateral position, meaning how close the door fits to the frame.
Attach the hinges first, then adjust gradually.
klo61
4 Apr 2023 11:05
Hello Finnsi, I understand your search for a clear guide very well.
To perfectly adjust the BESTA doors, you should proceed as follows:
- First, slightly loosen the hinge screws so that the door is still held in place.
- Then use the height adjustment (usually a screw at the top or bottom of the hinge) to align the door so that it hangs at an even height.
- Next, use the side adjustment, often accessible behind a cover. This allows you to move the door closer to the frame or pull it away to minimize uneven gaps.
- The last step is the depth adjustment, which is important to ensure the door is flush with the front and neither too far out nor recessed.
It is important to make only small changes to each adjustment and check the door’s operation repeatedly in between. If the screws are too small or hard to reach, a small step ladder can help you access the hinges better.
rekijan
4 Apr 2023 13:18
Hey Finnsi, working with BESTA doors can sometimes feel like a little puzzle, but with a bit of patience, you can manage it really well! 😉
I would recommend: First, make a plan to understand what each screw does (as described above). Then take each step calmly – start with height, then side adjustment, and finally the depth.
If you make a mistake, no problem: just turn the screw back. And keep in mind that slight variations in the walls or the assembly of the cabinet boxes can also have an impact, so don’t get discouraged!
Good luck, it’s always great to see a project go well and for the doors to close perfectly, just like they do in the furniture store.
Charles
4 Apr 2023 14:02
I would like to add that the hinges on the IKEA BESTA doors can have soft-close dampers. If your doors have this damping feature, you should check before adjustment whether the dampers are properly engaged, as they affect the closing force.
There is usually a small cover over the hinges that you can carefully remove to access the adjustment screws.
It is also important not to loosen the screws too much, as the hinge can come loose from its mounting. Always make small turns when adjusting.
If you have multiple doors next to each other, I recommend measuring the gaps with a small ruler to ensure an even alignment.
reni45
4 Apr 2023 14:45
Just a small addition regarding turning screws:
Most BESTA hinge models have a side screw for adjusting the distance to the cabinet front. This screw allows you to precisely adjust the gap between the door and the cabinet, especially when doors touch each other or are aligned in a row.
Height adjustment usually works with a screw at the front of the hinge, which also allows you to tilt the door slightly if it hangs unevenly.
