ᐅ What can I do if the doors on my IKEA BESTA cabinet are misaligned or uneven?
Created on: 1 Mar 2018 08:12
HiroakiSome time ago, I assembled an IKEA Besta chest of drawers, but I noticed that the doors are not hanging straight; instead, they are crooked. One door sticks noticeably at the bottom, and the other more so at the top. It looks like the hinges are not properly adjusted. What exactly can I do to fix the problem with the misaligned doors? Are there specific adjustment options on the hinges or other tips I should be aware of? The chest of drawers is completely level, ruling out assembly errors with the side panels. I am looking for a detailed guide or a step-by-step approach to correct this, in order to prevent further damage.
The issue with doors hanging unevenly on IKEA BESTA cabinets is often due to incorrect hinge adjustment. BESTA hinges typically have three adjustment screws: one for vertical alignment, one for horizontal alignment, and one for depth. You should first check whether the hinges are fully screwed in and if all screws can be moved. To align the door, use the horizontal screw to adjust the door sideways, the vertical screw to change the height, and the depth screw to set the distance from the cabinet side panel. Usually, the screws are adjusted in the following order: first, a rough height adjustment, then sideways alignment, and finally, the depth to ensure the door is flush with the cabinet frame. If the door still sticks, please also check the door hinges for any damage or deformation.
gaubla schrieb:
BESTA hinges typically have three adjustment screws: one for vertical alignment, one for horizontal adjustment, and one for depth. It’s interesting that this sounds almost like a universal solution. But honestly – maybe the issue isn’t always mechanical. IKEA furniture is known for standardized modules, but I would argue that some pieces come with minimal dimensional tolerances. In such cases, simply tightening or loosening screws might not be enough; sometimes a bit of patience and reworking is needed, like filing the hinges slightly if they don’t fit perfectly. Of course, that’s not for everyone, but when dealing with misaligned doors, it’s worth keeping manufacturing tolerances in mind.
gaubla schrieb:
So you should first check if the hinges are fully screwed in and if all screws can be moved. Thank you for this guidance. My hinges are fully installed, and I couldn’t find any loose screws. However, when I turn the screws on the horizontal axis, the height of the door also changes slightly. Is there a trick to prevent the adjustments from affecting each other, or does it just require a lot of patience to fine-tune?
Hiroaki schrieb:
However, if I turn the screws on the horizontal axis, the height of the door also changes slightly. This interaction is common with furniture fittings, especially with hinges that offer multiple adjustment options. Therefore, a step-by-step approach is recommended for precise alignment:
- First, roughly adjust the vertical alignment using the vertical adjustment screw.
- Then, align the door laterally using the horizontal screw.
- Finally, correct the depth.
Between each adjustment, be sure to close the door and check the fit, making slight readjustments to previous screws if necessary. This is an iterative process that takes time but ensures an optimal fit without causing damage.
