I have an IKEA Besta sideboard with the standard doors, which have warped slightly over time. Now I notice that the doors either don’t close completely or catch slightly. My question is: how can I properly and precisely adjust the doors in a Besta system to achieve an even gap width and optimize closing? Are there specific screws or mechanisms that need to be used, and what is the best procedure for an accurate adjustment? I would appreciate a detailed explanation, including tips on mistakes to avoid.
Phoenix3011 Feb 2019 09:36caio41 schrieb:
My question is: How can I effectively and precisely adjust the doors on a BESTA system to achieve even gap widths and improve closing performance?This sounds like a typical case of “door alignment.” Ikea usually uses a simple hinge on BESTA doors with three adjustment screws: one for height, one for side-to-side, and one for depth (how far the door sits against the cabinet). It’s important to work systematically here: first release any tension (e.g., loosen the screws), then adjust the height, next fine-tune the lateral position, and finally correct the depth.
But to fully understand your situation: How uneven are the gaps? Are the doors warped or are the hinges loose? Just to make sure we’re adjusting the right part.
Phoenix30 schrieb:
Ikea usually uses a simple hinge with three adjustment screws for the BESTA doors: one for height, one for side adjustment, and one for depthTo add: BESTA typically uses clip-on hinges that allow very precise adjustments. I recommend the following procedure:
- First, loosen the two large screws on the hinge that attach the door to the cabinet. This allows you to adjust the door height.
- Next, turn the small side screw to adjust the door laterally.
- For depth adjustment, use the screw at the front of the hinge, which controls the distance between the door and the cabinet.
Important: Not all hinges are the same; depending on the model, the arrangement may vary. It’s worth taking a close look and adjusting each hinge individually.
One more tip: If the door is warped, adjusting the screws will help but may not completely fix the problem. In that case, you might need to unmount the door and realign it or check with the manufacturer for suitable replacement parts.
What exactly are the gap measurements on your door? Are they different at several points?
kla69 schrieb:
What are the exact dimensions of the gap width on your side? Are they different in several places?Thanks for the clear explanation! The gap width actually varies in several places between about 3 mm and 6 mm (roughly 0.1 inch to 0.25 inch). The doors hang fairly straight but sometimes touch each other at the bottom – which occasionally causes slight sticking. The hinges themselves don’t feel loose, but I suspect the lateral adjustment is not optimal. So, I plan to check the height first, then the side alignment, and finally the depth.
One more question: Would it be advisable to completely unhang the doors to access the screws better, or is that not necessary?
Basically, it is helpful to remove IKEA BESTA doors for readjustment. This allows full mobility and better access to all the screws.
I recommend the following:
- Carefully remove the door (with clip-on hinges, this is usually done by slightly lifting and pulling it out)
- On a flat surface, roughly adjust the screws for height, side, and depth first.
- Make only small adjustments at a time to immediately see the effect.
Additionally, you should check the gap dimensions with a tape measure or caliper and test with light pressure to see if the doors rub anywhere.
Make sure that the cabinet sides themselves are straight and not warped. If the wood is warped, adjustments will have little effect.
What might help is to apply a bit more weight to the lower hinges, since the door sometimes sags at the bottom. But without pictures or exact specifications of the door, this is difficult to say.
Do you have soft-close or standard hinges?
