ᐅ How can I adjust IKEA Besta doors to ensure they close perfectly?
Created on: 4 Jan 2023 09:37
Sangi62Hello everyone, I recently assembled an IKEA Besta shelving unit with doors and noticed that the doors don’t close properly. Despite several attempts to adjust them, there is always a small gap or the doors rub against each other.
My question to the community: How can I adjust the IKEA Besta doors so that they close perfectly?
I am particularly interested in:
- What exact adjustment options do the hinges offer?
- Is there a specific procedure or sequence for the adjustment?
- When there are multiple doors, are there particular gaps or angles to consider?
- Is any special tool required for precise adjustment?
I want to avoid having to readjust them constantly and am looking for a long-term solution so the doors close flush and perfectly. Thanks for your tips and experiences!
Hey Sangi62, you really nailed it! Getting Besta doors to fit perfectly is definitely a bit of an art. The key is to use the adjustable hinges, which usually allow you to adjust in three directions:
- Height (up/down)
- Depth (forward/back)
- Width (side to side)
Typically, you should start by adjusting the height to align the doors on the same level, then adjust the depth to get the correct distance from the cabinet frame, and finally adjust the width for a flush fit when the doors close. A simple Phillips screwdriver usually does the trick.
By the way, sometimes it helps to remove the doors completely and realign them from scratch if things have gone quite off track. Stay calm, you’ll get it to work for sure! 😉
- Height (up/down)
It should be added that the IKEA Besta hinges have the following adjustment screws:
- Height adjustment via screws on the back of the hinge
- Side adjustment via a screw on the front of the hinge
- Depth adjustment through a screw to move the door closer or further from the cabinet frame
The recommended procedure is:
1. First, adjust the height (align the door with the cabinet frame)
2. Then adjust the depth (fit the door to the cabinet frame)
3. Finally, adjust the side offset to ensure flush closing
Tools: Medium-sized Phillips screwdriver, occasionally a hex key (Allen wrench) for finer adjustments.
Note: Even gap widths are important to prevent doors from rubbing or sitting unevenly. Proceed slowly and carefully using a delicate touch.
Hello everyone, here is a simple step-by-step guide to adjusting IKEA Besta doors:
1. First, open the door and locate the hinge. There are usually three screws:
- one for height adjustment at the back
- one for lateral alignment at the front
- one for depth adjustment also at the front
2. Start with the height adjustment: Slightly loosen the rear screw and slowly move the door up or down until the top and bottom edges of the door are evenly aligned with the shelf.
3. Next, adjust the depth: Use the front screw to move the door closer to or further from the frame. The goal is for the door to sit flush with the cabinet.
4. Finally, adjust the lateral alignment so that no doors rub against each other and the gaps are evenly spaced.
Tip: Work slowly and make small adjustments. Sometimes it helps to remove the door completely and reinstall it.
Make sure all screws are securely tightened after adjustment, but avoid over-tightening to prevent material deformation.
