ᐅ Are there upgrade options for the hinges on IKEA Besta units?
Created on: 15 Jun 2016 08:17
ArtisanHello everyone, I have a question that might be of interest to some of you: Are there upgrades or alternative hinges for IKEA Besta cabinets that go beyond the standard fittings?
I own several Besta units, and while the original hinges generally work, they don’t seem very durable or high-quality to me, especially with frequent use. I’m curious if it’s possible to replace the hinges with more robust, higher-quality, or simply better-functioning models without having to remove the entire door or make major modifications.
It’s also important to me whether such upgrades are compatible with the existing drilling pattern and how the replacement affects the door adjustment options.
Does anyone have experience with these kinds of improvements or know of specific replacement hinges that are recommended?
Hey Artisan! Great question – I recently upgraded my Besta doors myself and can share some tips! 😃
There are actually alternative hinges that are compatible, but you need to pay attention to the drilling pattern – IKEA usually uses a standard size, so many third-party hinges will fit. For example, I tried the Hettich Sensys hinges, which are very high quality and offer a soft-close function that really stands out!
The replacement can be a bit fiddly, especially the adjustment, but afterwards the doors move much more smoothly and steadily. Don’t get discouraged – it’s definitely worth it! If you want to know more about how to do the swap, I can gladly share more details.
Following the question: There are no official upgrades from IKEA for the Besta hinges. However, third-party hinges are partially compatible due to the Euro hole system used in Besta.
The most common are 35 mm (1.4 inch) concealed hinges, which use the typical drilling pattern. Manufacturers such as Hettich or Blum offer higher-quality versions with soft-close and damping features, often superior to the standard IKEA product.
Replacing them requires precise adjustment of the position, as otherwise the doors will not close properly. Additionally, some models offer better load capacity. It is important to carefully check the measurements before purchasing, as different door thicknesses require different types of hinges.
LEAH_TAN schrieb:
For example, I’ve tried the Hettich Sensys hinges—they are very high quality and offer a soft-close effect that really stands out!That sounds very interesting! Could you perhaps elaborate on how easy these hinges are to adjust? I often have trouble with the fine-tuning, especially for furniture where a tight closing fit is important.
RETRAVIS schrieb:
Replacing them requires precise adjustment of the positioning, otherwise the doors won’t close properly.How complex is the replacement under normal circumstances? Is it enough to swap the mounting plates on the cabinets, or should one expect additional drilling or modifications to the furniture?
Regarding the topic: Most high-quality hinges available from specialist suppliers are designed so that both the drilling pattern and the mounting method are compatible with the Euro hole system. For example, hinges with a 35 mm (1 3/8 inch) hole diameter are standardized.
For replacement:
- The original drilling of the Besta hinges should be preserved.
- No additional modifications to the cabinet are necessary, provided the door thickness is appropriate.
- Hinges from Geberit or Blum can be used as alternatives here.
Adjustment is relatively precise with the integrated fine-tuning screws. However, it is advisable to take time to align the door flush and ensure it closes properly.
For replacement:
So, I wanted to join the conversation! I installed Blum hinges myself, and they are truly amazing in terms of smoothness and adjustability!
A little tip: If you're at it, also get the screws with spring-back feature – it makes fitting the doors much easier.
And my advice for fine-tuning: a steady hand, some patience, and especially don't tighten the screws too much right away! Then everything works like butter.
