ᐅ How reliable are the hinges on IKEA Brimnes furniture?
Created on: 26 Oct 2020 13:47
O
Onjate
O
Onjate
26 Oct 2020 13:47
I recently purchased an IKEA Brimnes furniture piece and have been thinking more about the following question: How reliable are the hinges on Brimnes furniture?
Specifically, I’m interested in whether the hinges can withstand long-term use and stress, and if there are common weak points that could lead to issues such as warping, loosening, or even breakage.
It would also be helpful to know if IKEA provides any official information or recommendations regarding the load capacity or proper handling of the hinges on Brimnes furniture.
I don’t want the doors to stop closing properly after some time or even come off the hinges. If anyone has practical experience or informed opinions, I would be very grateful.
KAMERON
26 Oct 2020 14:03
The hinges on the Brimnes furniture are standard metal hinges with soft-closing features, commonly used by IKEA.
- The load capacity corresponds to the average for furniture in this price range.
- No special materials that are particularly impact-resistant, but also nothing considered low quality.
- In practice, they last several years under normal use.
IKEA usually does not provide specific information on the maximum load capacity of the hinges for Brimnes but relies on commonly accepted industry standards. It is important to avoid overloading the doors and to regularly check the tightness of the screws.
In case of significant wear, the hinges can be easily replaced since they are standardized components.
fiman
26 Oct 2020 14:18
I have had a Brimnes shelf for three years. The hinges are still sturdy, with no warping or wobbling.
rebufar
26 Oct 2020 15:02
KAMERON schrieb:
The hinges on the Brimnes furniture are standard metal hinges with soft-close mechanisms, commonly used in IKEA products.
It’s interesting that you rate the hinges as just 'average.' That’s exactly the problem: the "standard components" make the furniture cheap and quite generic.
In my opinion, Brimnes hinges are not suitable for heavy or long-term use, and often you only notice after several months that they start to loosen or the door closing mechanism becomes stiff. A customer with high demands will quickly reach their limit.
naujon
27 Oct 2020 09:21
Regarding the hinges on Brimnes, I would like to provide a brief guide on care and maintenance, which noticeably extends their lifespan:
- Regularly tighten the screws, as they can loosen slightly with use.
- Apply some silicone spray or a specialized lubricant to the joints if the doors squeak or become stiff.
- Avoid opening or closing the doors with excessive force.
By following these points, the hinges can function without issues for several years. Careful handling is important, as the material is fully adequate.
relupa
27 Oct 2020 10:50
rebufar schrieb:
That’s exactly the problem: the "standard components" make the furniture cheap and quite interchangeable.
I understand your criticism, but for many, Brimnes is a practical and affordable solution. Personally, I find it reassuring that the hinges can be replaced if there are problems and that they hold up well with normal use.
It’s important to remember that the furniture piece is designed for everyday use, not for heavy-duty or professional purposes.
For me, it was very helpful to first invest in adjustments and proper maintenance before getting upset about the material quality.
