ᐅ Which Ikea PAX doors are the most durable?
Created on: 31 May 2023 09:23
U
USPAU58
I am planning to expand my Ikea PAX wardrobe system in the coming weeks and am currently selecting the appropriate doors. It is particularly important to me that the doors not only look good but are also as durable as possible, since the wardrobes are used daily.
My specific question is: Based on your experience or known materials and construction methods, which Ikea PAX doors are especially durable? I am referring to factors such as scratch resistance, hardware stability, and overall robustness in everyday use.
Do you have recommendations on which door models perform better in these respects, perhaps compared to others, or tips on what to pay particular attention to when choosing?
I look forward to clear and well-founded responses!
theo63
1 Jun 2023 10:14
Interesting details, thanks for the information.
nubar schrieb:
Soft-close hinges from Ikea are generally low-maintenance.
In my view: maintenance may be minimal, but correct installation and load handling are even more important. If the door is not precisely adjusted, the hinges will wear out faster.
Therefore, my recommendation is to be patient during installation and, if necessary, make adjustments in the first few weeks to ensure the longest lifespan.
Paxton38
1 Jun 2023 11:03
theo63 schrieb:
Patience during installation and, if necessary, readjustments in the first few weeks will maximize the service life.
Exactly. For installation, I recommend the following:
- Always align doors precisely and securely fasten the hinges.
- Install soft-close mechanisms carefully to ensure smooth operation.
- Remove any sawdust or packaging material before fitting the door.
These tips significantly reduce mechanical wear.
Kukar
2 Jun 2023 07:59
One more tip: If you place a high value on durability, avoid doors with foil finishes. They tend to tear easily and are more fragile than melamine-coated fronts.
KNUTGI
2 Jun 2023 09:21
The discussion here keeps getting better! 😊 The "TYSSEDAL" doors are a good alternative if you prefer a slightly more traditional look and also value high durability.
They are less prone to damage than film finishes but require a bit more maintenance than melamine. However, the appearance makes up for it.
U
USPAU58
2 Jun 2023 11:54
Very helpful, thanks everyone!
Here’s a summary of what I’ve taken away:
- For high scratch resistance and everyday durability, melamine-coated MDF fronts are a good choice, e.g., "VOXTORP"
- Glass fronts are sturdy but require more maintenance
- Doors with frame and panel construction like "TYSSEDAL" are mechanically more stable and less prone to warping
- Soft-close hinges extend the lifespan but need careful installation
- Foil coatings are less durable
If anyone has additional input, please feel free to share.
Cecilera66
2 Jun 2023 12:39
I would also add that environmental conditions (humidity, temperature fluctuations) play a major role, especially if the cabinet is placed in the kitchen or bathroom.
This is where the difference between MDF and a wooden frame becomes noticeable: MDF swells less and remains dimensionally stable for a longer time.
