Hello everyone, I have been experiencing an issue for some time with my IKEA Billy bookcases where the doors seem to be too heavy for the hinges. Specifically, the doors are difficult to open and close, and as a result, they sometimes hang slightly crooked and appear to be under strain. I am curious whether this is simply a design flaw of the hinges, or if there are factors related to door size, material thickness, or installation that I should consider as a user to avoid or fix the problem. Are there known reasons why some Billy doors might be too heavy for the hinges, and what can I do to make the doors operate more smoothly and easily again?
difepeo schrieb:
Original BILLY hinges are specified only for doors up to a certain size and weightCould you please provide a specific source for that? I have read that the hinges are rather universally applicable, as long as the installation is done correctly.
I suspect that issues with "too heavy doors" might actually be due to improper replicas or incorrectly adjusted hinges.
Additionally, the question arises whether the loads really exceed the standard or if moisture or design factors might be the cause.
Linavin schrieb:
Can you please provide a specific source for that?IKEA itself states in the Billy assembly instructions that doors up to 40cm (16 inches) wide can be mounted as standard, and the hinges support loads of approximately 3-4 kg (6.6-8.8 lbs) per door.
Larger, heavier doors (such as glass or large solid doors) can indeed exceed these load limits.
This is no secret; hinges are often designed for lightweight doors and not for heavy solid wood doors.
Linavin schrieb:
Can you please provide a specific source for that?Take a look at the BILLY assembly instructions provided by IKEA. They explicitly recommend paying attention to the door size and weight to avoid overloading the hinges.
Additionally, various DIY forums report that replacement or retrofit doors often cause hinge load issues because the doors are either thicker or heavier.
Even when the doors are original, proper installation plays a crucial role. Only correct load distribution can prevent the hinges from being overstressed.
Thank you for your previous contributions! To add some information:
- I have standard wooden doors made of MDF, no glass doors.
- The doors are mostly 40cm (16 inches) wide and about 60cm (24 inches) high.
- The hinges are original from IKEA; I haven’t replaced any.
- The screws are tight, but the doors are not hanging completely level.
I will check again to see if the weight of the doors might be higher than usual due to the thickness or density of the MDF.
Would it make sense to use small glide bushings or lubricant on the hinges to make them move more smoothly? Or would that increase the risk of the doors slipping?
Also, it sounds almost as if I might need to work with stronger hinges from a third party if I don’t want to replace the doors.
Tyrese65 schrieb:
Would it be helpful to use small sliding bushings or lubricant on the hinges to make them move more easily?Yes, that can definitely help. A thin layer of silicone or graphite oil provides smoother movement and reduces friction.
I would only avoid aggressive oils or petroleum-based lubricants to prevent early damage to plastic components.
When hinges are properly screwed in and the screws are tight, the doors usually won’t slip. Such maintenance measures mainly extend the service life.
