ᐅ How can squeaky BILLY cabinet doors be fixed?
Created on: 15 May 2018 08:42
Dufeline
Dufeline
15 May 2018 08:42
I have noticed that the door of my Billy bookcase has been making a rather loud and annoying squeaking noise when I open or close it for some time now. I am mainly interested in how to permanently fix this squeaking without having to take apart the entire door or the bookcase. I have some basic understanding that the squeaking often comes from the hinges or fasteners, but I would appreciate specific advice on diagnosing the issue and the best repair methods, possibly including recommendations on materials or tools that work best for this. Maybe some of you have practical experience with this particular problem on BILLY doors?
Thanks in advance for your help!
lukin
15 May 2018 09:07
Hello Dufeline,
I’m familiar with the problem of squeaky BILLY doors. Often, the culprit is actually the hinge. As a first step, you can try treating the hinges with a spray lubricant (such as WD-40 or a special furniture lubricant). It’s important not to use too much oil to avoid it soaking into the wood surface and leaving stains.
If the squeaking doesn’t stop after that, the screws on the hinges might be a bit loose, causing friction. Simply tighten them with the appropriate screwdriver, but don’t over-tighten, as that could warp the wood or the hinges.
If you want to remove the door from the shelf to get better access to the hinges, this is usually easy to do by operating the mounting clips.
If you have any questions or need more details on specific steps, I’m happy to explain further!
V
vinli
15 May 2018 09:31
Additional information:
The squeaking of BILLY doors often results from dry friction between the metal parts of the hinges or between the hinge and the wood. In most cases, regular lubrication of the moving parts is sufficient to eliminate the noise.
It is important to use an appropriate lubricant. Silicone- or Teflon-based sprays are often recommended instead of oil, as they do not penetrate the wood as much and do not cause stains. Additionally, they last longer and do not attract dust.
If the door still squeaks after lubrication, it should be checked whether the hinge is properly aligned and firmly installed, since play or misalignment can also cause such noises.
Systematically working through these points usually leads to quick success.
O
olivernu
15 May 2018 10:15
I would like to point out that the hinge material used in BILLY is not particularly high quality, which can contribute to noise development. Unfortunately, wear and tear over the years may cause persistent squeaking.
In such a case, replacing the hinges is a sustainable solution. Replacement hinges, ideally original parts from IKEA, are affordable and relatively easy to install.
It is important to thoroughly oil the hinges before installation to prevent the problem from recurring for a longer period. If desired, the moving hinge parts can also be treated with graphite powder, which is very effective against friction noises.
For those who do not want to replace the hinges themselves, at least a thorough cleaning and lubrication should be considered.
neo59
15 May 2018 11:02
lukin schrieb:
The screws on the hinges are a bit loose
This is an important point that is often overlooked. I have experienced that exactly this issue can cause very annoying squeaking. However, I would add that the correct load distribution between the hinge points also matters. If a screw is slightly misaligned, it can also lead to friction noises.
Furthermore, I am skeptical that lubricants alone will help if the hinge is already heavily worn. In such cases, the cause of the wear should be examined more closely. It is possible that the hinge bushings made of plastic are also damaged, which can cause additional play.
Has anyone in this thread dealt with the problem of worn plastic parts in BILLY hinges before?
letar
15 May 2018 11:28
Regarding neo59’s question: BILLY hinges often come with plastic bushings or bearings. When these are worn out, the noise can rarely be fixed by simply tightening or lubricating.
In such cases, the hinge should be removed and the bearings or bushings inspected. Replacement parts are available directly from IKEA or from third-party manufacturers offering compatible components.
Alternatively, completely replacing the hinge is often more cost-effective and sustainable, as it fully restores the door’s functionality.
Practical tip: Use new screws during installation, as old screws can sometimes be stripped, which can also cause looseness and noise.
