ᐅ What can help with squeaky doors on Billy bookcases?
Created on: 22 Mar 2021 08:42
ezrafe
ezrafe
22 Mar 2021 08:42
I’ve been having an annoying issue with my IKEA Billy bookcases for some time now: the doors make a loud creaking noise when opened and closed. The sound clearly seems to come from the hinges or the fittings.
I’ve tried tightening the hinges a bit and adjusting the door, but the creaking persists. Does anyone have experience with how to specifically stop the creaking on Billy bookcase doors? Are there any particular products, lubricants, or tricks that can prevent the noise in the long term?
I would really appreciate any concrete tips, especially if based on personal experience.
FRANCISCOP
22 Mar 2021 09:03
Basically, squeaking usually occurs due to friction between metal parts or between metal and plastic in the hinge mechanism, often combined with insufficient lubrication.
For Billy shelves, I recommend the following procedure:
1. Remove the doors and thoroughly clean the hinges, removing dust and dirt.
2. Then apply a light, low-residue lubricant based on silicone or PTFE, which does not attack plastic and does not attract dust (avoid using WD-40 long-term).
3. If there are large gaps, check whether the door is properly aligned, as improper fitting can increase the squeaking due to uneven forces.
This is a proven method that helps in most cases.
semuneo
22 Mar 2021 09:26
I can definitely understand how annoying this creaking noise can be—especially with furniture you use every day.
I recently noticed that the doors on my Billy cabinet were squeaking slightly, and it really bothered me since guests noticed it too. After a thorough cleaning and applying silicone oil, the problem was almost completely gone.
If you're unsure which lubricant to use, you might want to try graphite powder first—it’s dry and doesn’t attract dirt. That might help as an intermediate solution.
O
olivernu
22 Mar 2021 10:15
An addition on the topic of adjustment:
Sometimes a slightly misaligned door that is not perfectly flush at the edges causes the hinges to be under tension, which can lead to noises.
My tip: Use a screwdriver to align the door in all directions and then check if the creaking still occurs. Especially with Billy-style shelves, hinges can be adjusted quite precisely.
Often the problem becomes easier to solve if you adjust the pressure points.
GEKAU51
22 Mar 2021 10:46
Let's be honest, who really expects top-quality door hinges on a Billy bookshelf? The creaking, to me, reflects the character of this piece of furniture—almost a signature charm of the IKEA brand.
But why bother messing with the mechanical parts? You could actually see the creaking as an acoustic signal, basically saying, "Cost-saving measures were applied here!" 😉
Jokes aside, maybe simply buying new hardware—different hinges—could help if it really bothers you. The IKEA hinges aren’t expensive.
JAFUHAU
22 Mar 2021 11:07
GEKAU51 schrieb:
The creaking, to me, is an expression of the texture of this piece of furniture, almost a charm of the IKEA brand.
I agree with that, but that doesn’t mean you have to accept it – I think it’s important to use your furniture and enjoy it without annoying noises.
Simply applying lubricant, as FRANCISCOP described, has helped me with other furniture. Just make sure not to use an oil-based product, since that attracts dust anyway, as you mentioned.
