ᐅ Why do the doors on some Billy bookshelves swing open on their own?
Created on: 2 Jun 2024 08:23
PIEL54
I have a somewhat unusual but very specific question: Why do the doors on some IKEA Billy bookcases seem to open by themselves?
I have noticed that on some units, the doors slowly open without being touched or with only very slight pressure. This doesn’t happen with every model or every bookcase, but sporadically, often only with relatively new or self-assembled ones.
I wonder if the issue is related to the design of the hinges, the assembly, or perhaps small unevenness that causes the bookcase or the doors to become unbalanced.
I am particularly interested in whether the door weight or the position of the hinges might play a role, or if IKEA uses a specific design feature that encourages this behavior.
Does anyone have experience, tips, or detailed explanations about why this happens and how to reliably prevent it? Thanks in advance!
Greglau
2 Jun 2024 12:09
If the doors still open, it might be that slight friction on the hinges is not enough. I recommend installing small rubber or felt stoppers on the inside to gently slow the door down without needing to close it forcefully.
peovin
2 Jun 2024 12:47
Doors that open by themselves are otherwise rare at Billy’s. Usually, as mentioned, it is due to the hinge or its adjustment. If these are not properly installed, gravity can cause the door to open on its own.
PIEL54
2 Jun 2024 13:15
tra_nina schrieb:
Material of the shelf matters
Thanks, that’s an aspect I hadn’t considered before. My Billy shelves are in a room that can be a bit more humid during winter. It’s possible that the material might warp slightly because of that.
loken schrieb:
Screw loose? Tighten it!
I had already checked the screws but hadn’t tightened them. I’ll definitely double-check that.
The idea of felt pads also sounds interesting in case I don’t get the adjustment exactly right. Thanks for the helpful suggestions so far!
Jukin
3 Jun 2024 07:42
I would like to add that IKEA shelves are often manufactured with tolerances to reduce costs. This means that not all hinges and drill holes fit perfectly, especially in mass production.
To prevent the doors from constantly "self-opening," calibrating the door position using the adjustment screws on the hinges helps. These allow you to precisely change the position of the door, which is particularly valuable for slightly uneven shelves.
I also recommend regularly checking whether the hinge play is still correct, as screws can loosen over time. If you still cannot find a permanent solution, small rubber buffers placed between the shelf panel and the door are a practical way to prevent unwanted opening.
If you are willing to put in a bit more effort, you can also switch to hinges with integrated damping and self-closing function. While these are more expensive, they completely solve the problem.
I hope this helps!
loken
3 Jun 2024 09:19
Jukin schrieb:
Hinges with built-in damping and self-closing function
Yes, if you want to get rid of the problem for good, this is a very good option. Unfortunately, not exactly cheap, but for me, the better long-term solution.
Basically, it’s kind of funny, because the Billy shelves almost act like a little physics demonstration: gravity, leverage, and material behavior in a home environment ;-)
Important: Always remember to tighten the screws regularly, otherwise it turns into a circus! 🙂
Jensson
3 Jun 2024 10:03
Jukin schrieb:
Screws loosen over time
Exactly, these details are crucial. Here’s an additional tip: when adjusting, follow this order – first properly set the top and bottom hinges, then adjust the sideways movement. This is the only way to ensure the best fit in the long run.
Also, if you use felt or rubber buffers, make sure the door isn’t pried open too far, as this could damage the hinges. Some trial and error here is normal and helpful.
Finally, don’t forget: some people report that removing light magnetic catches can also help, but that’s a matter of personal preference and not necessarily standard practice.
